Electric Brake Controller Hookup
GLK 350 hs a 7 pin connector, and my trailer is only 2500 lbs, but has electric brakes.
Any guidance or suggestions are very much appreciated.
Bish
My question is if the GLK has a under dash connector installed for electric brake unit control. I have seen reference to the capabilities of electric brake control in a review of the vehical, but it did not elaborate further. The sales guy at the dealership was no help either. He couldn't tell me, just expressed surprise that a 17 foot travel trailer has electric brakes. In other words, no help.
Anyone have a an answer or a suggestion how I could find out. I could call Mercedes directly, but likely I'll get customer service.
Check this, there is a section on towing starting on page 236. Seems that there is should be an adapter for electric breaks. I have the hitch prep but haven't looked into towing.
EDIT: I checked the interior today, and have no idea where the brake control would be installed. Maybe giving MB a call would clear it up. Keep us posted.
On a side note I check how hitch is installed....$540 is a fair price for it. Of course it cost MB next to nothing, but having this installed after the fact with the same quality will cost easily more than 500 bux.
Thanks,
Vance
No mess. No fuss.
Tekonsha RF is what it is called.
A little more expensive, but the saved grief and the fact that the controller unit can be used in ANY car subsequently is worth it.
Vance
3.5L
The only part of the install that confused me was the Curt wiring harness converter, I finally figured out that the tail light and the brake lights used the same single filament bulb only brighter when the brakes apply. Usually cars use a double filament bulb and have a seperate wire for the tail lights and the stop light.
I did use this thread when I searched for info on the brake controller and thought that it would be a good idea to put it here that it is possible to install a wired in brake controller and that the higher priced wireless one isn't a must on these suv's but may be a good option for someone that doesn't want to touch their wiring.
