BLUETOOTH WITH i PHONE
Using iTunes back up your contacts to Yahoo Contacts.
Export contacts to a VCard format.
Copy VCard files to a PCMCIA memory card.
Plug in PCMCIA card into COMAND (if you have one) and use COMAND to import VCard contacts info into COMAND phonebook.
I did this, not everything lines up perfectly, but it beats entering everything in manually.
There's more information at www.mercedes-benz-mobile.com but for some reason the GLK is not there so I just picked the c300. I compared all phones and there's only a handful that MB can import address book from. Most support VCard transfer. As yet the iphone doesn't support either one.
Andyf0's tip should work if you have a pcmcia memory card, otherwise either input it one at a time or copy your contacts to another phone and do the vcard transfer from there? Probably (hopefully) the updated firmware should have this support too.
Frank, are you saying the iphone voice command works via MB's bluetooth? I have 3g with 3.0 updates, I'm pretty sure it doesn't do that. I think its a matter of time that someone writes an app to bluetooth transfer contacts (functionality is there with 3.0)
also, another way to do this is to export your contacts to vcard and transfer via PCMCIA memory card.
Streaming stereo bluetooth won't work on MM, only UMI. This is MB issue not iphone (3.0 supports A2DP). Its been discussed in many other section in this forum.
I got the new I-phone as well but I can't seem to pair it with the bluetooth in the car
.What type of bluetooth do you have ??I never had a problem with my old original I-phone
Webada, does your stero bluetooth work? Here's the problem
I'm discusing in a differtent thread.
"So what should I do then?
I got iphone paired with the car. It works just fine. The Voice memos new application and hands free car audio works ok but when I start playing music on the phone it's played by the phone alone. The car speakers stay silent. I can't swith the music to the car audio. Is that beacuse the music is stereo and the other applications and phone calls are mono?"Could you possibly check on yours?
Re: Stereo Bluetooth (A2DP?) in iPhone 3GS
Posted: Jun 22, 2009 5:08 AM
in response to: marengo2
Email Mac OS3.0 does supposedly provide stereo Bluetooth via a car kit but it is not clear how to achieve this.
In my car I have a Mercedes Benz Bluetooth kit that allows hands free via bluetooth but when I play music via the iPod application I do not get to choose between the iPhone speaker and the car speaker. It plays from the iPhone speakers. I tried to 'trick it' by selecting MB during a phone call. This resulted in music being played via the car speakers simultaneously with the phone call. The sound was crappy - perhaps because it was mono only. When I hung up the phone call the music reverted to the iPhone speakers
Anybody?
Can any one with anything other than iphone that has stereo bluetooth support check?
Anybody?
I can confirm the case is true above. Its the only way i can get music out of MB speakers via bluetooth. I'm beginning to think this is really an iphone issue rather than MB. If ipod had a function to switch sound output via bluetooth or iphone speakers (just like the phone functions) then I believe MB will take it.
EDIT: No, I am sure now this is MB issue. MB bluetooth, as a sound output device, does not communicate to the originator as A2DP device. This is evident by iphone 3.0's ability to pair bluetooth headsets at ease without special functions. It just works via ipod once paired. Which means that MB bluetooth on MM package do not communicate A2DP (which also explains why it sounds mono)
I dont expect to have all answeard but who knows
Having Comand APS, does it make sense to add UMI? Is it possible to surf the web on comand aps?Like use it as an external monitor for Iphone's safari? After installing TV Free upgrade is it possible to have the TV, back up camera, Navigation and Ipod/Iphone tv out source all at once? Do I need a special TV tuner for it?
if you have Comand, you can't add UMI.
but I hear ya, it makes sense to have all those features and its certainly not hard to do. Think of the screen as your TV with multi outputs; connect to your computer for internet, AMP for music and cable box for TV, and eve a game console.
it tooks years before car maker decided they can stick a $50 dvd player into their console display.
Is this a unique problem with the BB Bold or something else? Anybody else having a similar problem?
