How often I should change engine oil for GLK?
I personally knew one of the chemical engineers that worked for Mobil for nearly 30 years before he retired. In contrast to popular belief, synthetic motor oil does not last any longer than conventional motor oils... think not? Then please show me where it's written that it does last longer and I'll show you a hoax. They may hint at it but I'm sorry to report, it isn't actually written anywhere that it does.
Syn oils do hold their properties a little longer, reduce friction at higher operating temperatures, are less prone to water retention, but they do become contaminated just like conventional motor oils do. Extended oil changes are a direct result of better engine manufacturing and engineering precision, thus less friction, less blow-by gases etc etc. However, there are other factors that contribute to oil breakdown regardless of what type it is. Poor driving habits such as pumping the accelerator instead of keeping a steady throttle, slow traffic commutes, cold engine starts, engine braking techniques, towing trailers, etc. These things all take a high toll on any oil.
We had a BMW that also required a 10,000 mile oil change interval with Mobil-1. At 100,000 miles, that engine was nothing but one large SLUDGE BOX... gummy and varnished with worn out valve stem seals blowing white smoke at every stop light.
If you took apart engines as much as I do, you would understand. Our new GLK will get the same initial treatment as all our new cars have.
Oil Change at 1000mi.
Again at 2000mi.
Then again at 4000mi.
Then every 4000 miles thereafter.
When you dismantle an engine after a 100,000 miles that's been treated like I describe above vs. one that hasn't or has followed the manufacturer's recommendation, it can be compared to a dentist looking into the mouth of a 50 year old person who brushed their teeth after every meal vs. one that only brushed before bedtime. Get the picture?
vs
Everyday driving is exposed to different weather conditions and everyone has different driving habits. Therefore, the best investment you can make to protect and have great longevity of your GLK.
My 2 cents...
Therefore, I would think dealer's recom oil change schedule should be at or near the optimal point. You can do that slightly more often, but anything beyond you will get a diminishing benefit while spending unnecessary time / money for it.
I don't think MB would under-quote the oil change freqency because they don't care about the damage after the warranty period. As higher ownership cost after warranty will drive the used car price down, then eventually hurt the new car sales or even brand name.
As far as all the speculation on MB's change interval, why not just send a few samples that were changed at the 10k mile mark to a lab for analysis? That should put an end to all of the debate.
But air contains water, right? As the engine heats up, the air condensates inside your crankcase where it soon vaporizes and mixes with combustion blow-by gases creating acids. It then mixes again with the engine oil. (There are hundreds of other contributing factors such as the fuel type used, combustion efficiency etc. but I'm not going there.) Now as this acid mixture increases over time, it dilutes the oil to such an extent that it not only reduces the antifriction properties of the oil, this oil and acid mixture starts to rot every metal component inside the engine, such as crankshaft and rod bearings, piston rings, valve & guides, cams… you name it… it’s getting attacked. So if the contaminated oil is not changed when the oil becomes too acidic (loss of viscosity and lubricating properties), DAMAGE will occur no matter HOW BIG your oil filter is or how FINE FILTERED they say it is.
As far as the correct oil is concerned, Yualfred is right; the oil MUST conform to the MB-229.5 specification. However, the correct viscosity and type used by the factory in our GLK is Mobil-1 Formula-M 5w-40. This oil must be used year round.
WARNING: Please do not confuse this oil with Mobil-1 ESP Formula-M 5w-40. They sound alike but they are NOT THE SAME. ESP is for diesel engines ONLY! Also, please DO NOT GET the “over the counter” straight Mobil-1 5w-40 either. This oil does not meet the strict Mercedes Benz 229.5 spec.
As far as the correct oil is concerned, he’s right; the oil MUST conform to the MB-229.5 specification. However, the correct viscosity and type used by the factory in our GLK is Mobil-1 Formula-M 5w-40. This oil must be used year round.
WARNING: Please do not confuse this oil with Mobil-1 ESP Formula-M 5w-40. They sound alike but they are NOT THE SAME. ESP is for diesel engines ONLY! Also, please do not get the “over the counter” straight Mobil-1 5w-40 either. This oil does not meet the strict Mercedes Benz 229.5 spec.
Although Mobil-1 Formula-M 0w-40 may be standard in Canadian models... but I'm not that sure. It would make sense due to your colder climate.
Question: Using 5W-40 Grade Motor Oil Instead of 0W-40 in a Mercedes-BenzI've been using Mobil 1 0W-40 synthetic oil in my 1992 500E Mercedes for 4 years now and have been told to consider 5W-40 grade for my car. I live in southern California, my mechanic only carries 0W-40 weight, and I want to ask if the 5W-40 grade is better then 0W-40 grade all around?-- Steve Vainshtein, Los Angeles, CA
Answer: Both a 5W-40 and 0W-40 will provide the same level of protection at high temperatures, especially if you are using a product like Mobil 1. As far as the 0W versus the 5W, this should not make a difference for you other than at start-up. The 0W would provide you a faster start-up at low temperature but you are unlikely to see the differences in your climate. Either grade is fine for you and unless you are having any issues, we recommend you stay with Mobil 1 0W-40 as it is specifically designed for your type of vehicle
Your logic is current for why using 0w-40 to improve low-temp pumpability while you don't need in warm climate. However I don't think it is fact that harmful additives are added, as from Mobil website, it doesn't seem to make difference. And for Canadian weather 0w-40 is a must. Also 0w-40 is much more popular. I can't even find non-diesel 5w-40 product info in their website.
That's an older benz you reference... so it doesn't apply here... MB engine design and materials have changed slightly since then.
This is the oil the factory currently uses in all NEW Canadian and USA GLK models. It can only be purchased at your local dealer for now. http://www.mobil.com/USA-English/Lub...la_m_5w-40.pdf
The commercial store version is a straight Mobil-1 0w-40 but make sure you look for the 229.5 Mercedes Spec on the bottle or box before you buy it. The commercial store Mobil-1 5w-40 is NOT to be used since it doesn NOT meet Mercedes specs.
But like I said, in order to have multigrade oils of any kind, viscosity extending additives are blended in. Our race cars use a straight single weight synthetic... and sometimes a racing blend syn multigrade 10w-30/40. The more the spread, the more additives there are... period... there's no other way to do it. That's why Mercedes uses Mobil-1 Formula-M 5w-40 and NOT 0w-40 from the factory.
So do what you wish... I'm sure it will be okay... but do not get the ESP Type-M whatever you do... just Formula-M.
Good luck.....
Has anyone actually got an oil analysis by Blackstone or the like to determine whether the longer oil runs are prudent? I've seen an oil analysis using mobil 1 synth that went 17k miles and the blackstone analysis stated the oil was in good shape and could have actually gone longer.
