Since the battery is in the engine compartment, how did you route the power cable for the amp to the the back? Is there a rubber gromet on the firewall that I'm not seeing that has easy access into the cabin? I did a quick look around from the top today and didn't see anything. Maybe there's something from underneath.
You'll need to open up behind the SAM module (fuse box housing on the drivers' side) to gain access to the firewall.
It is there, as I have seen my tech mechanic do his part for routing some wires of my project lighting.
Not easy though. Good Luck.
I'll have to check out that location.
I found a write up on a C300, and the guy found an empty gromet on the passenger side underneath behind the battery. I'm hoping there will be a similar one on the GLK, but I'll have to remove the battery to see:
original thread:https://mbworld.org/forums/c-class-w...r-install.html
Quote:
it is located under the spare tire. You'll see a plastic circular shaped box...Originally Posted by HDRyder9
Where is the factory sub woofer located?
So I bought all the parts for the subwoofer install. I decided to go with an Alpine Type R...had one in my previous car and it was really nice. I'm going to run the power wire from the battery into the cabin tomorrow and then wire in the line out converter into the the rear door speakers. I'll try to post some pics up with the process.
Quote:
What kind of amp and converter are you using? I have a Fosgate 600x1 amp with a Audio Control LC8 to a JL audio 12w6v2. I might change the LC8 to JL audio Cleansweep. Good luckOriginally Posted by koojo
ExploreQuote:
Alpine SWR-1243D 12" sub (600 rms)Originally Posted by jdm2010
Alpine MRP-M500 amp (500 rms at 2ohm)
Scosche 2 channel line out converter, nothing fancy just simple converter to tap off the rear doors.
Have you done your install yet?
Got it installed at a custom audio shop last year. It took a few days and I paid 500$. You might want to get a better converter, you might have sound quality and feedback problems. They used 3 different converters when finally the LC8 worked. Sometimes with the radio off I get strange feedback through the speakers. That is why I might be changing to JL audio Cleansweep. I hope yours works out please keep us updated.Originally Posted by koojo
Alpine SWR-1243D 12" sub (600 rms)Alpine MRP-M500 amp (500 rms at 2ohm)
"Sometimes with the radio off I get strange feedback through the speakers."
It's stuff like that that makes me not want to mess with my cars...
Well good than, don't. Wouldn't want to hurt that car, that metal is precious..Originally Posted by rmfnla
"Sometimes with the radio off I get strange feedback through the speakers."It's stuff like that that makes me not want to mess with my cars...
Quote:
Sorry to bring back an old thread, but does anyone know if the sub enclosure under the spare will accept a larger sub woofer?Originally Posted by mr.mbenz
it is located under the spare tire. You'll see a plastic circular shaped box...I really want more bass. I've got the HU settings as high as they will go.
[RANT]
Cars that can shake my rear view mirror when sitting behind me at a stop light. The driver of the other car must be loosing their brain cells and hearing at an alarming rate.
[/RANT]
Wayne
[/RANT]
Wayne
[/RANT]
Wayne
What? Cannot hear you.Originally Posted by venchka
[RANT]Cars that can shake my rear view mirror when sitting behind me at a stop light. The driver of the other car must be loosing their brain cells and hearing at an alarming rate.
[/RANT]
Wayne
Thank you for that. Very helpful.
Not sure. It is easily accessible but have had not a chance to dig in there yet.
I was thinking of applying more damping material to the ABS sub box.
Nah, my time is too valuable to me to go chasing down issues I caused by screwing with a perfectly good car.
If I want a better stereo (or whatever) I'll order it from the dealer with the car. Then the whole thing is under warranty, and if there are any problems they can deal with them.
