Should get headlight covers
Old Nov 12, 2010 | 11:16 PM
NYCGLK's Avatar
GLK 350 / Porsche 993
So there is CL63 parked one car over. It's newer design so can't be more than 4 years old. The headlights have this foggy tint on them already. I hope xpel covers will prevent this from happening.
Old Nov 12, 2010 | 11:47 PM
MBRedux's Avatar
Nissan GT-R BE / '12 Ducati-1199 Panigale S / '12 C300-4M Loaded/GLK350-4M Loaded
This is what heppens when you either run your car through too many car washes, (harsh detergents) or apply wax to your polycarbonate lenses when you detail your car.
Old Nov 13, 2010 | 03:44 PM
NYCGLK's Avatar
Good to know,
off topic but how's rest of your fleet holding up?
Would really love to get either used GT-R or Cayman down the road. I know those are two very different cars.
Old Nov 13, 2010 | 09:20 PM
MBRedux's Avatar
The GT-R is just a fantastic car. I simply love driving my Nissan GT-R on long interstate trips. (Surely it's Nissan engineering at its finest. Much better quality than their Infiniti line IMO) It is so advanced, so fast when needed, it's beyond anything I have ever owned or driven before!
http://www.youtube.com/watch?v=WSzNE17f1PY
Thanks for asking!
Old Nov 14, 2010 | 08:59 AM
MilesBFree's Avatar
GLK
I used the Meguire's plastic polishing kit on the covers on my Dodge Ram and it worked great. I am sure similar kits from Eastwood, Mothers, etc. would do about the same.
This shouldn't be needed on our GLKs yet, but maybe a few years down the road...
Old Nov 14, 2010 | 09:38 AM
MBRedux's Avatar
These polishing kits are fine for most lenses, but the MB uses a slightly harder PC lens, plus it's super clear. If I had to use something on it to keep it clean without wax build-up it would be a product called "Nu-Finish". Trust me, it worked wonders on my Nissan GT-R. Took off the yellow completely WITHOUT leaving any scratches whatsoever.
Old Nov 14, 2010 | 10:00 AM
GLKKa2H's Avatar
2010 GLK 220CDI 4M BlueEFFICIENCY
An option to polishing kits could be replacing the moisture that the plastic loses by oils, with a product like: http://www.swissvax.us/merchant.mvc?...&Category_Code=.
Old Nov 15, 2010 | 02:40 AM
n5160u's Avatar
E320 CDi 2k SLK230 Designo 04 SLK 320 Final Edition 2010 GLK350 06 VW Beetle TDi 2012 Plug In Prius
What kills headlight lenses quickly is Ultraviolet radiation and the cleaners commonly found in window cleaners like Alcohol and Ammonia.
The window cleaners will cause microscopic cracks to develop in the surface of the plastic lenses by direct chemical reactions with the plastic.
Ultraviolet radiation causes the plastic to break down resulting in the same microscopic cracks developing.
Most headlight lenses have a thin UV absorbing coating applied to both sides of the lens to protect it from Ultraviolet radiation from external sources like the sun and from within if the vehicle has HID lighting. If this coating is damaged or polished off by improper cleaning the lens material is quickly damaged.
As an old airplane driver I have known of this issue for over thirty years since most aircraft don't have glass windows. Most any pilot shop will sell window cleaners that are rated as being safe for "Aircraft Transparencies" These items have to pass testing by the people who manufacture aircraft windows before being rated as being safe to use.
See this for more details:
http://www.lpaero.com/CAREINS.html
A typical cleaner is like this:
PlexALL leaves an antistatic protective coating on all aircraft windows both plastic and heated glass. PlexALL is also safe to use on cockpit instruments and displays. Water Based, Non corrosive, Alcohol & Ammonia Free. Meets Boeing Spec. D6-17487P & D6-7127M
Attached Thumbnails Should get headlight covers-aircraft_helicopter_window_cleaner_polish_gm.jpg
Old Nov 15, 2010 | 07:22 AM
MBRedux's Avatar
^ Sounds good. Where can it be purchased and for how much?
Old Nov 15, 2010 | 08:57 PM
MKenM's Avatar
2010 GLK Black, Premium 1, Lighting, Multimedia, Appearance and Media Pkg, 2012 Corvette Grand Sport
Wow, buy one get one free!
http://www.autogeek.net/dp-plex-all.html
Is this different from the product you recommended?
Old Nov 15, 2010 | 10:51 PM
MBRedux's Avatar
I didn't recommend it, but it is not the same. This is what N51.. recommends...
http://cgi.ebay.com/ebaymotors/ws/eB...d=350374391469
Old Nov 16, 2010 | 03:52 PM
rmfnla's Avatar
2013 Infiniti G37 Coupe; 2011 GLK 350 w/ Premium 1, Multimedia & Sport Appearance; I LOVE IT!
Thanks for asking!
Pooh.
