GLK running boards - Is this OEM? (pics)
I purchased a pair of running boards for my GLK from eBay. The seller claims that it's an OEM piece, but it came in an unmarked box and does not have any paperwork that says that it's an OEM piece. It does not even have a mercedes logo or the name anywhere.
A few other things that I am not so happy with are...
1) It is missing two nuts. It's supposed to have 10.
2) Both pieces says "rechts" (right in German) although it's a pair of right and left ones.
3) The finishing of the rubber bushings on the aluminum is suspiciously poor.
Can folks who have installed running boards themselves please chime in?
See pics below...
Thank you very much.
How much savings did you obtain?
Does this answer from your seller:
"Description: Factory Running Board Fit which model: 2010-2011 Mercedes Benz GLK-Class Condition: New-In-Original Package Material: Aluminum Save over 50% from factory retail price with our factory style aluminum running board with the same look and functionality !! OEM Factory Style Sport Running Board Made of Aluminum 100% new-in-original package!! Direct bolt to the factory pre-drilled holes Perform just like factory running board kit Side protection to your 10-11 Mercedes Benz GLK-Class OEM fitment designed for easy installation & Installation instruction is included!"
The boards in your picture look EXACTLY like what I got at the Dealer. IMO the boards are mostly for show. One of my running boards was missing one of the rubber studs. When I investigated why I found that some of the studs, three I think. One at each end and one in the middle are somewhat holding the assembly together. When you install these be careful if you have to loosen them to adjust. They don't come off very easily and if you pull to hard to get them back off, you can snap one of the studs because three of them actually go all the way through the assembly to hold the aluminum down against the plastic. If this happens it sucks because you cannot buy the studs for these things.
The biggest PITA when installing these things is making sure they are straight and snap all the way on. You want to be sure they are exactly where you want them before you push them on tight because they are difficult to remove. It is actually pretty tough to push them over the clips all the way on just under the rear doors. Its hard to explain without a diagram but I am sure you will see exactly what I am talking about when you install them. The fit is very tight because they are cut perfectly to match the GLK. This is a good thing because it looks really good after proper install. But the perfect fit means hard to push on areas.
http://cgi.ebay.com/ebaymotors/ws/eB...#ht_500wt_1182
Mine came in one non-original box. I am very handy when it comes to cars, but I don't want to go through the pain of installing it unless I am sure it is an OEM part. Repos usually looks almost like the OEM ones, but they don't fit as good since they are not made out of the original molds. The first job for me is to make sure it's an original piece.
Here's another eBay ad for a used original piece. The seller is showing a picture with the part number and am MB logo on it. Mine does not have anything on it, which is what concerns me.
http://cgi.ebay.com/ebaymotors/Merce...#ht_1038wt_941
So Sorry ,You are not happy about its, As I answer your,this item I get it online,this OEM part not Original part of Mercedes,no number on.You undestand its new and 2 nuts thread check beford packing so it opened.the screw hold may be shipping make it cracked.my description no refund and return,I try my best to resovel to You,don't thing original part it may be $999.00 not $330.Please try install its, no one know oem in YOU CAR you will happy.
- vinpeng
" Definition: OEM stands for Original Equipment Manufacturer.
Does that clear it up? Probably not. Acronyms are funny like that. The real definition is easy to understand. OEM is usualy used when referring to auto parts. If a part is called OEM, it was made by the manufacturer to be used in your car when it was new, and can be bought later to replace a broken part. For instance, if you drive a Ford, an OEM window crank was built by Ford to be used in your car. The window crank you see hanging on the rack in the auto parts store is not an OEM part, because it was manufactured by somebody else and only used to replace the window crank Ford installed on the assembly line.
Since nothing is as simple as it could be, there's more. Sometimes Ford hires an outside company to produce all of their window cranks for that year. Let's say they hire Acme Parts to make them. In this case, Acme is the OEM supplier for window cranks, making them official Ford parts since they were installed on the assembly line. So they can sell Ford window cranks later, under the Acme Parts name, and still call them OEM window cranks."
It could be that these are OEM look-alikes and/or they are suppliers to MB and therefore they are not able to provide manuals or anything of MB logo on it due to laws preventing them to do so.
Finally, f.y.i.
Mercedes GLK-Class Running Boards
A204-690-0675
$491.04US
Genuine Mercedes GLK-Class 2010-2011 accessory
sold at mercedes.dealerfit.com
Get this... the sellers definition of OEM is "Other Equipment Manufacturer"
(this is their 'no strings, no service' approach)
From your E Bay Link
"Mercedes Benz GLK280 GLK350 2006-2011Running Board OEM"
To my knowledge there is no such thing as a 2006 GLK in fact I don't think there is such a thing as a GLK 280. That should have been your first tip off.
"OEM" It is probably true the company that made these running boards makes Original Equipment and they are Manufacturers.
They don't accept returns, another tip off.
From the E Bay Listing:
"This is Branch New Mercedes GLK Running Broad with all nut ,From Year 2009-2011. No reserve prices ,No return accept,only ship in 48 States and paypal confirm address, if You have any question,please email to me.Thanks"
Do you think this person has a grasp of the English language "Branch New" "Running Broad" "with all nut" "No return accept" "any question"
I know you might say that he didn't use spell check but his poor use of the language might give you a hint that he is well not from the US. Brooklyn another hint.
"New: A brand-new, unused, unopened, undamaged item in its original packaging (where packaging is applicable). Packaging should be the same as what is found in a retail store, unless the item was packaged by the manufacturer in non-retail packaging, such as an unprinted box or plastic bag. See the seller's listing for full details. "
Another hint that this is not an MB product.
I am not biased but this listing wreaks of buyer beware.
Best of luck I hope they fit right and wear well. I hope you prove me wrong.
Saving 500 bux on a shady product for 40-50k car just doesn't make any sense to me.
Live and learn, hope they fit at least.
2046900675 Each $575.00 $575.00
$432.40 Side Running Boards
Add a touch of form and function to your GLK-Class with our stainless steel running boards. Step surface has a brushed metal appearance dotted with rubber grips which helps prevent slippage.
What OP brought was a replica of the "OEM factory style" running board. I wouldn't buy it if it doesn't have a MB part #.
https://sites.google.com/site/glkrunningboard/home
They are bigger morons. Best case they will refund me for the cost of the item and shipping, but I will end up having to pay for shipping the item back to the seller, which is $70.
eBay should be responsible for keeping an eye on idiots like this selling crappy items on their site.
This is not to rub it in because I hope you are able to get your money back and by the way false advertising could be a criminal offense if you pursued it (probably not worth it) but for others, look at their conditions, from the E Bay sellers site:
Condition
New
New other (see details)
A new, unused item with absolutely no signs of wear. The item may be missing the original packaging, or in the original packaging but not sealed. The item may be a factory second, or a new, unused item with defects. See the seller's listing for full details and description of any imperfections.
For everyone take the time to read the fine print.
Although in this case, they have at least shown the details of the 'New' and 'New Other' right on the item details page.
Early this year, I bought an out of state car from eBay. The 'Title' filed said 'Other - Specified in the description' The description did not say anything about the title, so I messaged the seller to see if it had a title. He messaged me back saying that it had a clear title. I bought the car and a week later it arrived without a title.
The seller refused to take responsibility so I contacted eBay's resolution center. They eventually granted the case in the SELLERS FAVOR.Turns out that as per eBay's policy, they will favor the seller if the seller had specified the title as 'Other - Specified in the description' even though in my case the seller had lied to me and deceived me through eBay's own messaging system.
For everyone - Read all fine prints before bidding/buying.
I hope you can get your money back.
Nick
I think rajid is going to get the "real" MB ones
