Rear Window Breakage
Old Jun 16, 2011 | 09:01 PM
CA Bob's Avatar
2011 glk 350
Strange thing happened today, I parked the car outside a store and went inside for about an hour. When I came out the rear window had cracks all over it, there was no glass inside, just on the bumper. When I opened the hatch to check inside most of the remaining glass fell into the back. I can't imagine what would cause the window to break like that, temps were only about 90, car was in the sun. Any ideas on what could cause something like this?
Old Jun 17, 2011 | 10:37 AM
knhellesky's Avatar
2011 GLK 4Matic, Black, AMG, PP, MP
Did it get hit by something/someone?
Old Jun 17, 2011 | 11:39 AM
CA Bob's Avatar
2011 glk 350
Rear Window Breakage.
There was no sign of damage from the outside, other than the left and right sides of the rear window were laying on the bumper in small pieces. The rest of the window was covered with cracks and fell apart when I opened the hatch. I would have expected a dent from a rock or something in the middle, but it wasn't there. The other strange thing is that the bigger fragments fall apart when you handle them.
Old Jun 17, 2011 | 07:34 PM
EnigmaAW's Avatar
2021 G63
sounds like a vandal? porcelain will spiderweb glass without making a sound. or somebody hit it with something. My glk parks outside at work all day, and it has been 100 degrees almost everyday for the past week. So i don't think heat would do it.
Old Jun 17, 2011 | 09:32 PM
CA Bob's Avatar
2011 glk 350
Anything is possible, I just have never seen the whole window spiderweb from a hit from a rock or baseball bat. That coupled with the fact that the only glass knocked out of place fell outside the car added to my confusion.
Old Jun 19, 2011 | 10:00 AM
GLKKa2H's Avatar
2010 GLK 220CDI 4M BlueEFFICIENCY
In case the window was exposed (facing directly) to the sun, the culprit could be the manufacture of this particular window. There is always tension involved as a function of the production, more or less evenly distributed over the window. With the curvature of the window in mind, and the fact you found the pieces outside, I would say it is not unlikely that this window was subject to a failure based on bad workmanship.
In case you have had no incidents like hitting it with sharp objects etc, I would bring this theory (hypothesis?) to the dealer, ask for their opinion and possibly indicate a due warranty claim.
Old Jun 19, 2011 | 01:01 PM
MKenM's Avatar
2010 GLK Black, Premium 1, Lighting, Multimedia, Appearance and Media Pkg, 2012 Corvette Grand Sport
Have you ever seen one of these. It is an amazing tool in case of emergency or in cases of vandalism. It has a pointed spring loaded head that when applied to a window and the trigger is pulled will smash a window into tiny pieces. Fire fighters and EMT's usually carry them. It doesn't leave much of a trace if any at all. This may very well have been the culprit.
Old Jun 19, 2011 | 05:54 PM
GLKKa2H's Avatar
I, for my part, do even have one easily at hand in the the car. It's certainly an useful tool in an emergency situation (either ones own or others), to cut safety belts or break windows when (electromechanically operated) door locks doesn't disengage.
However, in the case of CA Bob, I would expect finding fragments of the window inside if such a tool had been used from the outside, not at least bearing in mind the tilting (angle) of the rear window.
Old Jun 19, 2011 | 09:47 PM
CA Bob's Avatar
2011 glk 350
Thanks GLKKa2H, I'll try running that past the dealer when I take it in on the 22nd.
Old Jun 25, 2011 | 07:59 AM
NYCGLK's Avatar
GLK 350 / Porsche 993
That's how car windows break, except for the windshied. That's for safety, glass breaks into small pieces so it doesn't slice you. In 2nd grade we used to go to car junk yard and break remaining glass on cars, once you break it the whole thing spidewebs.
Old Jun 28, 2011 | 12:03 AM
n5160u's Avatar
E320 CDi 2k SLK230 Designo 04 SLK 320 Final Edition 2010 GLK350 06 VW Beetle TDi 2012 Plug In Prius
An "Automatic Center Punch" which can be purchased from most tool and hardware stores for a few dollars works the same way and can destroy a tempered glass window with only one hit. If you make the initial impact point over the part of the window that is bonded to the window frame (usually that is under the black painted outer edge of the glass or at the edge of the older window mounting gasket) the window will completely shatter but not fall apart.
I have destroyed hundreds of windows that way when I used to part time at a salvage yard.
The simplest explanation is often the closest to the truth. Your window was broken because somebody wanted it broken. With the bad economy there are a lot of Mercedes haters out there.
Old Jun 30, 2011 | 04:03 PM
CA Bob's Avatar
2011 glk 350
I've been out of town, but finally got my GLK back from the dealer today. The rear window was replaced under warranty with the write up saying that it was "stress cracking".
Old Jul 1, 2011 | 04:45 AM
GLKKa2H's Avatar
You're welcome. I am glad you got it sorted out - and covered!
