Steering
Old Nov 2, 2011 | 05:19 PM
420tee's Avatar
Red GLK350, blue '87 Toyota Land Cruiser
Steering
Is it a "Mercedes thing" that the steering wheel does not spin back to center after a right angle turn like every other car I've ever driven does going back to a 1939 Ford? If I let it go it will continue to turn. Tire pressure is about 35.
Old Nov 2, 2011 | 06:43 PM
MBRedux's Avatar
Nissan GT-R BE / '12 Ducati-1199 Panigale S / '12 C300-4M Loaded/GLK350-4M Loaded
Again, please you new guys... use the search forum section to find topics.... this topic is well known here and has been discussed since late 2009. Yes the steering on the GLK sucks. It doesn't self center because of poor engineering geometry, however it's worse on the those models with 4 Matic and the 20" wheel option.
Old Nov 2, 2011 | 07:11 PM
venchka's Avatar
2004 Volvo XC70; 2012 GLK 350 4matic
Now I find out. All the more reason for the GLK to arrive with 17" wheels.
Wayne
Old Nov 2, 2011 | 08:52 PM
420tee's Avatar
The more I find out about this "world class" vehicle I bought the more the name YUGO comes to mind.
So OK, I went to Search This Forum, typed "Steering" and it returned every post about everything under the sun except steering. Did MB design this website also?
Old Nov 2, 2011 | 09:08 PM
emdem's Avatar
2013 E550 Coupe
You should just sell it - it sucks and you will never be happy with a sub-standard vehicle. Sell it now before it depreciates more and you're stuck with it. It's all about what makes you/us happy. I know I wouldn't want to hang on to something that constantly disappoints and b*tch about all the time.
Old Nov 2, 2011 | 09:34 PM
MBRedux's Avatar
You see I drive this most of the time...
.... and I bought my wife the GLK... which we both drive and enjoy. It's been great... we love it!
After the GT-R, any car, and I mean any car will be a disappointment. So when I say the steering on the GLK sucks, consider what I am comparing it to... The steering is fine for what it is... You should give it another chance. It's a SUV for Pete's sake, not a GT-R or an AMG.... enjoy it. Sounds to me that you want out anyways, and will find anything to support your hatred of the car so........
......... I fully concur with emdem ^ .... stop crying and get rid of it. Bye bye...
Old Nov 2, 2011 | 09:58 PM
icool007's Avatar
2011 GLK350 4MATIC, 2013 GLK350 4MATIC
I love your GT-R!!! Hopefully someday I can get one of those
Old Nov 2, 2011 | 10:17 PM
emdem's Avatar
2013 E550 Coupe
Holy crap that's hot!
Old Nov 2, 2011 | 10:53 PM
venchka's Avatar
We don't expect a GT-R. We do expect precise steering, reliable braking, an A/C system that does not grow mold & mildew, rattle & bang free body structure, fireproof ignition system ... did I forget anything? Oh, parts installed according to the order form.
That isn't too much to ask, is it?
Wayne
Signing off before this place drives me crazy.
Old Nov 3, 2011 | 03:22 AM
emdem's Avatar
2013 E550 Coupe
Sell it! I never had any of those problems. Oops - yours is still on order... good luck with that...
Old Nov 3, 2011 | 07:54 AM
420tee's Avatar
Wayne
Exactly.
Old Nov 3, 2011 | 08:27 AM
MBNA109's Avatar
2015 VW GTI.S4; 2016 Audi Q3 Prestige
Exactly.
Cut bait.
Old Nov 3, 2011 | 08:42 AM
venchka's Avatar
Cool
I can only hope that I get a good one.
Wayne
Old Nov 3, 2011 | 02:16 PM
bop11's Avatar
350 GLK, C280
All MB's should self-center. Its an alignment thing, not a MB thing. The problem is that your steering angle (see atached) is wrong. The camber adjustment on strut cars is based on perfect body alingment due to its being a monocoque design. MB knows this and actually has a special bolt for the dealer to install in cases like yours where the normal adjustment won't make up for the body build tollerance. (also see attached). You are not really adjusting camber but steering angle. However, the two are interdependent and steering angle is what makes the car come back to straight. Get the thing aligned correctly. If your dealer can't do it, again, find one that can and will!
File Type: pdf
Old Nov 3, 2011 | 02:41 PM
venchka's Avatar
Thank you! Very useful to know.
Old Nov 3, 2011 | 06:01 PM
MBRedux's Avatar
Thanks for the heads up but God knows I've tried. I have done it all with only a slight improvement. Not only did the GLK go back a few days after I bought the car, I have had it in my own shop (we're a NISMO tuner) several times as well.... the alignment, caster - steering axis/angle, toe and camber are dead on. (We own a Hunter Hawkeye/ProAlign system.) Those repair bolts are only needed if the car has been in a minor front end collision and after its been repaired it still needs a little more adjustment than usual.
After an exhaustive attempt to correct this issue, we have concluded that it must be an geometric/engineering flaw that not even an advanced wheel alignment technique can solve. We only noticed a slight improvement.
Old Nov 3, 2011 | 11:42 PM
MBRedux's Avatar
Thanks! It is a spectacular car and the secret envy of many automakers.
