Cabin Air Filter and Engine Cover
Old Mar 26, 2012 | 11:03 PM
csmax's Avatar
GLK350
Where are the cabin air filter(s) and how do you replace?
How do you remove the black large plastic engine cover (not the smaller front one)?
Old Mar 27, 2012 | 07:51 AM
edulinka's Avatar
ML 350 2014
Which one for GLK 2010 and where to buy
I found this "How to change it" but which one and where is best to buy for GLK 2010?
https://mbworld.org/forums/c-class-w...er-change.html
Old Mar 27, 2012 | 07:49 PM
MBRedux's Avatar
Nissan GT-R BE / '12 Ducati-1199 Panigale S / '12 C300-4M Loaded/GLK350-4M Loaded
https://mbworld.org/forums/glk-class...hange-glk.html = UK / = USA / = McClaren
Old Mar 27, 2012 | 10:39 PM
csmax's Avatar
GLK350
Cabin air filter was easy. Now how do you remove the larger rear plastic engine cover(smaller front one is easy), so that I can change the engine air filters.
Old Dec 9, 2013 | 08:53 PM
mjhawkins2346's Avatar
2016 GLE300d 4Matic
Pull off the 2 air pipes on the left and right. The pull off the 1 inch air return line to the air pump (in the front). The large cover just pulls off. It has 4 large clips that snap onto 4 rubber "snubbers" or bumpers on the intake. It takes a firm steady pull. No you won't break anything (that's not a promise - just reassurance). It pulls mainly up and then forward. The filters are on the underside held on by 4 Torx screws per side. Make sure the filter is firmly seated on the cover piece before you seat it back down. You need to work the edges down ( I used Factory - OEM MicroStar LX-804S). They don't easily drop into the groove. If you don't, the covers won't seat properly - don't force it.
