Resetting clock on standard Audio 20
Old Mar 10, 2013 | 10:09 AM
piotrcane's Avatar
2011 GLK 350 4MATIC
Newbie here. Just purchased a 2011 GLK 350 4MATIC for my daughter. How do I change the time on console and on the standard Audio 20 (not command, dont think). Can not find it on line or it is anywhere in manuals. Thanks in advance.
Old Mar 10, 2013 | 12:31 PM
greasykid's Avatar
2015, ML250 BlueTEC
Changing time.
See if you have access to a "settings" tab. That is where I have the time changing info on my 2013 GLK350.
Old Mar 10, 2013 | 05:48 PM
GLKKa2H's Avatar
2010 GLK 220CDI 4M BlueEFFICIENCY
Given the GLK has the standard Audio 20 and no COMAND, the Time/Date submenu is available via the Settings menu of the Multifunction Display.
Select Settings, and then press up- or down arrows to access the Time/Date submenu.
Old Mar 10, 2013 | 06:14 PM
piotrcane's Avatar
2011 GLK 350 4MATIC
There is no Settings menu! How do I find it? SYS only takes me to display, language, etc...
Old Mar 10, 2013 | 06:43 PM
GLKKa2H's Avatar
Configuration of the On-Board computers / Multifunction Displays are country specific. Does the GLK have a twelve buttons multifunction steering wheel?
Old Mar 10, 2013 | 09:44 PM
cindyclk's Avatar
Here is the manual...pg 121...do you have these options....trip...phone...service etc....one of them should be settings.
Hope that helps.
http://www.mbusa.com/vcm/MB/DigitalA...l/2010_glk.pdf
Old Mar 11, 2013 | 06:13 AM
GLKKa2H's Avatar
The OP is in possession of a MY 2011, so the page referred to would be #171.
Then there isn't a Service menu (with corresponding Time/Date submenu) IF the GLK in question does have the 4-button multifunction steering wheel. If so, that calls for a different procedure with regard to setting the date/time.
Old Mar 11, 2013 | 07:21 AM
cindyclk's Avatar
Glk is correct on pg 171...here is link to manual.
http://www.mbusa.com/vcm/MB/DigitalA...l/2011_glk.pdf
Piotrcane, does that work for you?
Old Mar 11, 2013 | 09:58 AM
420tee's Avatar
Red GLK350, blue '87 Toyota Land Cruiser
Isn't it a bit ridiculous to have to go through all these steps and books etc. just to set the damn clock? Gee whizzery overdone to the max. Leave it up to these clowns and you''l need an ee degree to flush your toilet.
