*Sneak Peek* 22" Vossen CV3
Vossen CV3 Matte Black / Machined Face
22 x 9
Offset ET 38
BP 5x114.3 (used "wobble bolts" to fit them to the 5x112 GLK)
Currently they came with 245/30ZR22 Hankooks which are way to small for the GLK fender wells IMO but I wanted to post a picture for the time being for reference. I'm currently torn between running a 265/30ZR22 (identical overall diameter as the stock 235/45ZR20s) or a 265/35ZR22 (more meat on tires, fills the fender wells better, but 3.4% larger overall = less mpg, more rolling mass, more wear and tear, possible rubbing).
On to the "teaser pic"
I'll be sure to add more pics and info once I make my tire selection.
22 x 9
Offset ET 38
Currently they came with 245/30ZR22 Hankooks which are way to small for the GLK fender wells IMO but I wanted to post a picture for the time being for reference. I'm currently torn between running a 265/30ZR22 (identical overall diameter as the stock 235/45ZR20s) or a 265/35ZR22 (more meat on tires, fills the fender wells better, but 3.4% larger overall = less mpg, more rolling mass, more wear and tear, possible rubbing)...
My wife went with 20x8.5. I believe she's running 245/40/20 all around. I would have liked a bigger wheel but then the lower profile becomes an issue. Unfortunately in So Cal with the economy the last number of years, all road maintenance is few and far between leaving potholes a common place occurrence. The risk of wrecking a wheel is all too likely.
I like that you have gone beyond stock. The stock 20s that your GLK came with are nice, but this set up makes you an individual.
.....thanks for sharing.....What about ET 38....much lower than original....no issues with rubbing?
