TIRES SIZES FOR GLK
Old Jan 10, 2014 | 09:16 AM
bghart2003's Avatar
2010 E CLASS COUPE 350
TIRES SIZES FOR GLK
Has anyone fitted wider tires to their GLK?....19"....like a 245/50/19 or a 255/50/19 on stock rims?....Pros?...Cons?
Old Jan 10, 2014 | 09:00 PM
shotgun_banjo's Avatar
'13 GLK350 4matic,'10 C207,'15 GLA250,'07 Honda Odyssey, '18 GLE 43, '24 EQS 580
I wanna know to but for the stock 20" rims
Old Jan 12, 2014 | 09:58 AM
hceptj's Avatar
GLK350 4Matic
I just had Yokohama YK580's in 255/50/19 put on our's...they are way better than the Dunlop's that came on the car...quieter, much better in the rain and did good on the ice we had a month or so ago.
Old Jan 12, 2014 | 12:42 PM
bghart2003's Avatar
Thanks, I know by going to a 255 there are many more tires to choose from...plus the 8" width of the rims should be fine...did you notice any clearance problems with the 255's? Brian
Old Jan 16, 2014 | 02:02 PM
C32Berg's Avatar
GLK 320CDI - 2009 / SL500 - 2003
The stock 20" rims are equipped with 255/40 rear and 235/45 in the front...
Old Jan 16, 2014 | 06:02 PM
ble2716's Avatar
Very very slow
Is your GLK equipped with 4matic?
Old Jan 16, 2014 | 07:36 PM
107123210's Avatar
So that is what they install in Sweden as stock tires on GLK? Presumably your GLK320 has same sheetmetal work as GLK250350 we get in NA so same clearances?
In NA, the stock 20" tires are as follows (BA means both axles):
BA
235/45 R20 100 H XL M+S
8.0 J x 20 H2
Wheel offset: 1.77 in (45 mm)
BTW: If we can use wider tires and rims without interference, that would mean we would have a much greater chance of picking up a used set from an ML coming off lease. Wonder if the offsets are same? Diameter is slightly greater for usual snows which are 235/65R17.
Old Jan 18, 2014 | 10:55 AM
hceptj's Avatar
GLK350 4Matic
Nothing yet...and the bigger tire gives a little more clearance from the curb...
Old Jan 18, 2014 | 07:31 PM
mikedr's Avatar
2014 GLK350
Are you going 255 on all 4?
Old Jan 20, 2014 | 08:34 AM
C32Berg's Avatar
Some more information around the stock 20" set-up we run here in Europe / Sweden.
Front: 8,5 x 20" ET 45 / Rear: 9,5 x 20" ET 57 with the the tire set-up mentioned above.
I have the 4matic feature on my GLK. The front and rear circumference is withing 1 to 2 % so no worries...
We use the same GLK body as you guys in NA....
