aftermarket DRL
Old Sep 1, 2014 | 06:53 AM
edgar86's Avatar
GLK CDI 320 2009
aftermarket DRL
Hello ,
i ordered one set of some cheap DRL , wanted to know if anyone got these on their GLK ?
http://www.aliexpress.com/item/LED-C...447617602.html
I would like to wire them so it come on with the car runing , and it come off when headlight are switched on. or even on when the car is runing , any idea on the wiring ?
Old Sep 1, 2014 | 12:21 PM
EmiG310's Avatar
2010 GLK350
Originally Posted by edgar86
Hello ,
I am curious about these. I have seen these kits on eBay as well. Can you please let me know how it works out, I would be keen to do it if it's good quality and works as stated (auto on/off). Apparently they can wire up straight to the battery via an included box that controls the on/off somehow?
Old Sep 1, 2014 | 02:57 PM
edgar86's Avatar
GLK CDI 320 2009
I will give you some info when it get here , should be soon .
I dont know about the control box , but i noticed that on top of the led bar there is something like another light , the orange thing .
Does the second light work with the low beam , i dont know ?
Overall the DRL chinese unit dont look that bad , and it ill replace my foglight , that i never use
Old Sep 1, 2014 | 03:05 PM
EmiG310's Avatar
2010 GLK350
Yes That's supposed to be a turn signal. I don't think you would want to wire that part. I saw another kit that doesn't have the amber turn signal bar, it's more like the OEM DRL which only has the white led strip.
This is the kit I'm talking about: http://www.ebay.com/itm/For-Benz-GLK...-/271449787518
No amber strip, just DRL LED. Anyway Please post pictures of your work I'm very curious to see it!
Old Sep 1, 2014 | 04:54 PM
edgar86's Avatar
GLK CDI 320 2009
i cant see your EB link , it says forbiden in my country .
Old Sep 1, 2014 | 07:17 PM
EmiG310's Avatar
2010 GLK350
http://www.ebay.es/itm/For-Benz-GLK3...-/271449787518
That's Ebay Spain, same listing.
Old Sep 4, 2014 | 04:55 PM
rmfnla's Avatar
2013 Infiniti G37 Coupe; 2011 GLK 350 w/ Premium 1, Multimedia & Sport Appearance; I LOVE IT!
Several other sellers have what is probably the exact same thing for a bit less $ (don't forget shipping!); here is one:
http://www.ebay.com/itm/For-BENZ-GLK-CLASS-2008-2012-LED-DRL-GLK300-2x-Daytime-CAR-Specific-Running-lamp-/361005426738?pt=Motors_Car_Truck_Parts_Accessories&hash=item540d99a832&vxp=mtr
Old Sep 9, 2014 | 06:57 AM
edgar86's Avatar
GLK CDI 320 2009
i received the LED quality is ok , iam trying to install them now , the stock foglight assebmly is held by many clips that are not easy to remove .
Old Sep 9, 2014 | 10:07 AM
EmiG310's Avatar
2010 GLK350
Any pictures? Does the wiring look like it will just plug in? I assume you compared the parts and it will fit before you take everything apart?
Old Sep 9, 2014 | 11:12 AM
edgar86's Avatar
GLK CDI 320 2009
Hey ,
Iam using the box provided with the DRL , + - and dimming function.
I went straight at it like a warrior , and what a battle to remove this original foglight , really so much sweat went , pulling , pushing , no i have one led in i go back for the second one .
I didnt check nothing before starting , and i dont think i can use the foglight plug because it might throw a code
the dimming is nice it light off the led bar and light the amber bar above led .
Now where to wire the + that it light up the led , after the car started ?
Old Sep 9, 2014 | 04:19 PM
edgar86's Avatar
GLK CDI 320 2009
Hey iam finally done with the DRL install , it look amazing , will take picture ASAP.
I wired it on a switched live , i still need to wire the diming when headlight are on .
I dont know where to put this dimming wire yet .
The thing is i have hallogen headlight , yellow tint , and the dimming amber from the DRL will match it nicely once wired to dim
*Because now the led are blue and the headlight yellowish
