Is lowering a 2010 GLK 350 4matic easy as swapping springs?
Yes, you can drop it using springs. However, it will be on the very limits of alignment specs. To reduce excessive tire wear, it would be advisable to also look into camber plates for the front. There aren't any options available for the rear as of yet.
If you need the arms just send them an email telling them that you need arms for a x204. I got mine in 2 days.
https://mbworld.org/forums/c-class-w...g-springs.html
For the rears, just unbolt the single bolt on the LCA where it pivots nearest the center of the car.
thank you my senior wise one!😇
And plan on replacing the shock/strut mounts as well. Do it all once and get it over with.
Coilovers are the better (ie, more expensive) long-term solution.
Cheers again man!
