GLK 350 2010 Xenon light problem
I'm a new member on this usefull forum and I'm coming with a new question.
This week the right side xenon light burned out. D1S 4300K. It started getting a rosy color before shut off. Then I got a message on the panel that my right crossing light was not operating.
I bought a pair of those lights and plugged a new one but it did not light. I tried the other one, samething. So I would like to know if there is a fuse that could have blown out at the same time of the light or if there is a separate ballast to drive the light I d'like to know where the hell they hided it and how to reach it.
I would greatly appreciate if somebody would be so kind as to help me with this problem.
Regards
Thank your for your advice.
Unfortunatly I can't see anything close to the bulb that looks like a ballast.
Here we currently have a snow storm that will probably stand late tonight.
Tomorrow I'm going to check for fuses 5 - 29 -30 - 31 - 32 it would be nice
and much less expansive fixinig the issue with a blown fuse.
If you have any idea where the right side ballast is hidden it would be great.
Thanks very much.
with a flexible fiber optic tool to find where the braided cable will lead me, I hope to the ballast, and try to fix this isue by myself because the closest dealer is at a little more than 400 km from my place.
as you could say.
I will let you know the results of my investigation.
Tanks
I'm coming back to let you know the results of my researches.
First the xenon light control module, the ballast is located under the housing. You can touch it with the end of your fingers when reaching from the top but it is not easy.
To remove it you have to remove the wheel then the front part of the mud guard, then it is possible to reach it.
To remove it you have to unclip the light washer hose and take it off in order to be able to reach one of the retaining screws. There are 3 screws.
The MB part no. for this module is A2048703226 You can see the module following this link http://www.alibaba.com/product-detai...48.51.1.YiW27n
The MB local dealer sell it for 600$ can dollars before sale taxes an shipping. I ordered it on eBay New and unused from Germany for 155$ can dollars including delivery with 10 to 15 day for delivery. So I am very confident to fix my problem with elegance because mine was completly burnt. I opened it and just the smell was toxic
I hope to be helpful for someone.
