Replacement of the brake pad sensor mandatory?
Old May 10, 2017 | 07:35 PM
Hugo L.'s Avatar
2014 GLK250
Basically, if the wear sensor hasn't triggered a warning yet, can I re-use them upon replacing the brake pads?
Old May 10, 2017 | 07:59 PM
ItalianJoe1's Avatar
2003 CL 600
Theoretically, yes. In practice, they are quite fragile, and when removing/reinstalling, they can break and end up triggering a false warning immediately or at some point in the future.
Factory says replace them every time they are removed. I have changed pads that were barely worn under warranty for noise concerns or whatever, and you always put a new sensor in.
Old May 10, 2017 | 08:30 PM
Hugo L.'s Avatar
2014 GLK250
All right, thanks!
Old May 11, 2017 | 09:18 AM
bop11's Avatar
350 GLK, C280
Sure you can reuse it, but as Itallian Joe1 said "they can break" That has happened to me only once although I have reused them many times. At the less than $4 cost, why would you want not to replace it? After that one failure I will replace them every time.
Old May 11, 2017 | 09:56 AM
Hugo L.'s Avatar
2014 GLK250
I was just wondering, given that A) I have to go buy them at the stealership and B) they will likely charge way more than 4$ here...
Old May 11, 2017 | 05:41 PM
2003 CL 600
Even at full pop from the dealer they are under $20. Buy them online if you aren't in a rush.
Old May 11, 2017 | 07:39 PM
Hugo L.'s Avatar
2014 GLK250
It's one on the front and one in the back right?
Old May 11, 2017 | 08:53 PM
2003 CL 600
yep one per axle
Old May 13, 2017 | 05:45 PM
louiet3's Avatar
2009 C300 Sport Palladium Silver & 2012 GLK350 4matic Black
Paid $9.50 for the sensor @ the dealership because I needed it asap.
Price online is obviously less - amazon.com @ 6.99 each but not sure if this is OEM.
Old May 15, 2017 | 01:59 PM
Hugo L.'s Avatar
2014 GLK250
Ok, so less than 10$ apiece at the dealership. Not bad.
