2013 GLk 350 Engine Rattle
Old Nov 14, 2017 | 01:52 AM
Moaltar's Avatar
2013 GLK 350 4Matic
Question 2013 GLk 350 Engine Rattle
Hi Everyone,
I just recently purchased a 2013 GLK350 4Matic with about 50k miles. Everything felt/sounded good when I test drove it, but recently I have noticed that during a cold start I hear a rattle/clank noise under for hood. I've searched the forums and it seems like this may be the secondary timing chain tensioner problems the earlier M276 engines were having. I only get the rattle during the first few seconds when the engine is started.
I was going to take it back to CarMax since my 30 day warranty is still active, but I'm a bit worried that they wont fix it right since this isnt a normal problem.
Would I be better off just having the dealer do the fix so that i can be done right? Or has anyone attempted to the fix themselves? I've seen a video posted on youtube and it doesnt seem that hard.
Any advice is greatly appreciated!
Old Nov 14, 2017 | 02:25 AM
JohnnyC's Avatar
2015 GLK350 & 2020 C300
https://mbworld.org/forums/new-m-cla...ease-help.html
Its a very straight forward fix, although not that simple. If you were to do it yourself you will need special tools such as a torque wrench and E-torx sockets. I actually had this cold start noise as well, but it went away after I did my most recent oil change (owned GLK since March 2017).
Old Nov 14, 2017 | 09:18 AM
Mmr1's Avatar
2013 glk 350
I think there is a TSB bullitan on it , I would go talk to the dealer, I have the same issue and have not had it fixed. I would not let car max do any work,
Old Nov 14, 2017 | 09:27 AM
Mmr1's Avatar
2013 glk 350
Old Nov 14, 2017 | 10:49 AM
Moaltar's Avatar
2013 GLK 350 4Matic
Thanks for the post Mmri. Thats the same bulletin I've been looking at.
I was also thinking the same thing about CarMax. I just dont think they will service the car right. I'm gonna call the dealer next to my house and find out how much it will cost. I'm just barely outside my warranty too, so I wonder if they will cut me some slack and give me goodwill repair.
Old Nov 14, 2017 | 11:13 AM
Mmr1's Avatar
2013 glk 350
Car max should pay for MB to do it, let us know what you find out, I need to get mine done, but it only makes the noise when hot outside.
Old Nov 14, 2017 | 11:27 AM
Moaltar's Avatar
2013 GLK 350 4Matic
For sure, I'll let everyone know what they say. Mine pretty much does it whenever I start the car after it sits for a while. Mercedes apparently have good sound deadening material because I only noticed it when the window was down. Cant really hear it when I start it with the windows up.
Old Nov 17, 2017 | 10:55 PM
Moaltar's Avatar
2013 GLK 350 4Matic
So I got my GLK back from the dealer today and they said everything is fine. They had it for about 2 full days starting and testing the engine. They checked for any software updates, and any performance issues with the engine. Apparently the noise im hearing is the direct injection system. I agree that im not use to the noises of a direct injection engine ( ive only ever owned hondas and acuras), so maybe they are correct.
I may get a second opinion after i drive it some more. Although, they said my vin didnt bring up any technical service bulletins and everything was ok.
Old Nov 18, 2017 | 08:47 AM
Mmr1's Avatar
2013 glk 350
The only time I hear the noise is when it’s real warm out in summer, not now in fall. I don’t hear it on first startup. I must drive it till it’s fully warmed up, Park it for about 30minutes, then On startup it rattles for 3- 5 seconds.
Old Nov 19, 2017 | 12:05 AM
Amir_AMG's Avatar
Veteran: Air Force
2000 SL500
If the noise is from the direct injection it would be a constant noise throughout the whole time car is on...mine sounds like bees buzzing
Old Nov 19, 2017 | 08:27 AM
Mmr1's Avatar
2013 glk 350
I think Mercedes doesn’t want to fix it under warranty so they just say it’s normal
