GLK250BT Adblue TEMP Sensor
Old Sep 7, 2018 | 11:00 AM
TIFFI's Avatar
GLK250
Unhappy GLK250BT Adblue TEMP Sensor
I try to find similar topic but didn't see one after gone through almost 15 pages of threads.
We have this 2014 GLK 250BT bought brand new and now is under 70KM. The yellow engine light came on last week and the dealer checked saying the temp sensor in adblue tank has a short circuit with code 205C16. The car is still running seems normal, but on one trip on highway, it came out a large amount of blue smoke. It stopped after we got off the road. The dealer also warned it needs to be fixed with a new Adblue tank otherwise the car won't start in winter (we are in Canada) for $2200+.
Is TEMP sensor the similar function as NoX sensor as I saw some discussions around that topic? Also is the maintenance at 65KM cost $1200 normal? The maintenance was done three months before this trouble so no early sign of the sensor failure could be detected? Wondering if anyone here had experienced the same problem and can share with us.
Old Sep 7, 2018 | 12:34 PM
GLK Super Fan's Avatar
GLK250 ML350
which province you are in? if u r in the province without emission test, i will recommend you to do the dpf delete. If you are in the province with emission test, u can do a adblue software disable. There is nothing wrong with your vehicle. it just the emission parts have extremely high failure rate and the parts for repair are super expansive.
Old Sep 7, 2018 | 12:39 PM
andreigbs's Avatar
GLK 250
I would invest in an MB specific code reader, clear the code and see if it comes back.
If the AdBlue temp sensor is indeed bad, you may need an entirely new DEF tank installed as the temperature and level sensors is internal to the tank.
It's actually a module that is inside the DEF tank, almost like a fuel pump assembly, except the pump is at the top of the assembly.
What you need, most likely: Part# 204-471-05-75 and it's about $890. Most dealers will want to replace the entire DEF tank since it comes with a new temp and level sensor assembly, hence the $2200+
The AdBlue temp sensor is used to preheat the DEF fluid when it's freezing out. If it doesn't work, the DEF may crystallize and your emissions equipment (DPF particularly) may be compromised.
If the AdBlue system is compromised, it will give you a warning of "10 starts remaining" but this is to protect the DPF, it has nothing to do with the engine not being able to start in winter.
Old Sep 7, 2018 | 01:02 PM
GLK250 ML350
Give this guy a call, he can just do the adblue bypass
Old Sep 7, 2018 | 02:05 PM
TIFFI's Avatar
GLK250
Thanks guys for replying, we are in Toronto yes do need emission test after 7 years. The dealer said the $2200+ comes with 2 years warranty but usually things happen after that.
That really helps andreigbs. We have the code reader.
Old Sep 7, 2018 | 04:40 PM
GLK250 ML350
if u r in Toronto, i will call around. Alot of shops do dpf delete and tune. i believe there is one close to yorkdale area. Also, make sure u call around for the emission shop and see which one can do a guarantee to pass.
Old Sep 8, 2018 | 10:36 PM
bugelrex's Avatar
glk
Does Canada have an 8 year emissions warranty for New cars similar to USA?
Old Sep 11, 2018 | 11:36 AM
TIFFI's Avatar
GLK250
Nope, it's 7 years.
