Another problem. Leaking transmission.... sigh.
Old Jan 31, 2019 | 06:47 PM
Van Ha Nguyen's Avatar
2016 CLA 45, 2013 GLK 350
A good mechanic of mine lifted up the car to check the drive shaft issue. We found a leak from the transmission as well. We think it’s leaking from where the drive shaft enters into the transmission, but then it could also be leaking from somewhere else since the area looks darker . This is a 4matic. 2013 GLK350 with the 722.9 7G Tronic +
Do I have to replace the whole transmission? Is it leaking very bad? I had the fluid and filter replaced about a year and a half ago. Can the output shaft seal be replaced without opening the transmission? Time to sell the car??
Old Feb 1, 2019 | 12:36 AM
Mmr1's Avatar
2013 glk 350
Fill it up to check amount of loss , maybe it was overfilled at the service .
Old Feb 1, 2019 | 02:32 AM
Mmr1's Avatar
2013 glk 350
Or i mean re service it, overfilling might have caused a leak, it’s crazy there isn’t an easy way to check for fill level . But don’t wait to let it go low. It may not be low now, so measure what you remove .
Old Feb 1, 2019 | 03:08 AM
exhaustgases's Avatar
LS400
Easy fix, likely $100. repair at a small independent shop, or less if a person knows how to fix it.
Old Feb 1, 2019 | 08:55 AM
what needs to be repaired? Is it the drive shaft seal or the seam between the transfer case and transmission? Thanks!
Old Feb 1, 2019 | 08:57 AM
i want to get it checked, but it’s too hard finding an Indy mechanic with the proper tools to check the fluid level. I don’t want to get shafted by the dealer either. Does this transmission 722.9 tronic + NAG2 have an overflow breather? It may have been overfilled like you said.
Old Feb 1, 2019 | 01:38 PM
So I lifted it again and double checked this morning. It wasn’t leaking, when I drove for 20 miles, it started leaking again after I lifted it up. It’s coming from the output shaft seal to the rear axle.
Old Apr 10, 2021 | 03:02 AM
Jimmy Hristov's Avatar
2010 Mercedes GLK350 4Matic, 2016 BMW 435i
Mine looks similar but worse. Does this look like th output shaft seal?
Old Apr 10, 2021 | 09:04 AM
yeah looks like the output shaft seal. I didn’t get mine fixed. It only leaks in the winter when it’s below freezing outside. It’s been parked in the garage most of the time now since my wife is on maternity leave so I take the second car. I guess the seal shrinks in the winter and goes back to normal in the summer
Old Apr 10, 2021 | 02:37 PM
formerjeepguy's Avatar
2015 GLK350
The guibo joint looks bone dry and the transmission looks wet much further up from the output shaft seal. While the output shaft may be leaking a bit, most of the leak is coming from something forward of the output shaft.
Old Apr 10, 2021 | 04:17 PM
Mmr1's Avatar
2013 glk 350
Just checking the level will cost a lot , maybe 100$, a real good mb idea and design!
Old Apr 10, 2021 | 09:41 PM
yeah looks to be a couple of issues. Leaking output shaft seal and maybe the seam between the transfer case and transmission. Mercedes uses an RTV sealant to repair the leak. I think there was a TSB for this.
