TPMS replacement
Old Apr 11, 2019 | 11:47 AM
srb1194's Avatar
2015 GLK 350
TPMS replacement
My daughter is replacing tires soon. She has a 2015 GLK. I'm thinking of replacing the sensors. I have the MB part number and they can be found at about $50 each online. Can anyone offer any advice or recommendations regarding?
Thanks!
Old Apr 11, 2019 | 11:51 AM
JohnnyC's Avatar
2015 GLK350 & 2020 C300
I bought an aftermarket set back in 2017 for about $60 a set for my 19" wheels. You just gotta match the specs. Still works fine now.
Old Apr 11, 2019 | 11:53 AM
srb1194's Avatar
2015 GLK 350
Do you recall any issues of reprogramming or relearning? I'm apprehensive of going against OEM.
Old Apr 11, 2019 | 01:54 PM
andreigbs's Avatar
GLK 250
Unless your current TPMS sensors are faulty, why replace them? I got new tires put on this past January, the guys just rebuild them as part of the normal mounting of new tires. If the battery in a sensor dies and needs to be replaced, that's a different issue.
The tire shop should know how to remove and reinstall TPMS sensors as part of a new tire mounting. You don't need new ones unless the current ones are faulty.
Old Apr 11, 2019 | 04:58 PM
Mmr1's Avatar
2013 glk 350
I just got new tires and have original 2013 sensors.
Old Apr 11, 2019 | 06:37 PM
srb1194's Avatar
2015 GLK 350
I'm told you can't replace the batteries. The sensors have to be replaced when the batteries fail. I was just trying to be ahead of the failure. Maybe I'm guilty of overthinking this, wouldn't be the first time either. I do appreciate the input.
Old Apr 11, 2019 | 08:04 PM
Mmr1's Avatar
2013 glk 350
Don’t buy the factory tires, Michelin , Pirelli and others make a much , much better tire.
Old Apr 11, 2019 | 08:08 PM
srb1194's Avatar
2015 GLK 350
I'm assuming you're referring to the Dunlop Run Flats. If so that's my plan. I'm going with the Michelin Premier LTX. Agree?
Old Apr 11, 2019 | 10:15 PM
kombifan's Avatar
2010 Mercedes GL450; 2000 Mercedes ML55 AMG; 2016 VW GLI SEL Stick!!!
I'd only start worrying when the car is 10 yrs old. Youre a 2015 so dont bother. I'm in a 2010 and still on original tpms sensors.
I did have to replace one sensor though, but that was because of salt corrosion and the shop broke it.
Old Apr 12, 2019 | 05:05 AM
srb1194's Avatar
2015 GLK 350
Thanks for the reassurance.
Old Apr 12, 2019 | 05:07 AM
Mmr1's Avatar
2013 glk 350
The Michelin premier are maybe the best, I have them, but now you will need a spare, a jack and air pump.
Old Apr 12, 2019 | 05:09 AM
srb1194's Avatar
2015 GLK 350
Unfortunately true. Run flats just aren't my choice.
Old Apr 12, 2019 | 11:23 AM
andreigbs's Avatar
GLK 250
Add another vote for Michelin Premier LTX. It feels like a completely different car, actually rides like a Mercedes is supposed to.
Old Apr 12, 2019 | 02:44 PM
srb1194's Avatar
2015 GLK 350
Can't wait. Thanks!
