tires
Old Jun 21, 2019 | 10:41 PM
caroline hickey's Avatar
glk350 s550
tires
I need new rear tires and discovered the previous owner installed larger tires than recommended.
Car calls for 235 50 R19 The tires on the are are 255 50 R19 107V. I know all tires must be identical so should I return to the original size or keep the larger width tires?
Thank you
Carol H
Old Jun 22, 2019 | 02:15 AM
Marek_Norway's Avatar
2009 GLK 220 cdi
that's not truth, your tires are original for 19" rear rims for GLK...I have 17" on mine, rears are 255/55/17 and fronts are 235/60/17...similar for 19"
Old Jun 22, 2019 | 11:42 AM
glk350 s550
thank you for responding
c
Old Jun 22, 2019 | 03:29 PM
formerjeepguy's Avatar
2015 GLK350
I have a stock rear wheel drive 2015 GLK350 with factory 19 inch wheels. My tires are 235/50/R19.
If you have 4matic then yes, you need to use the same tire size on all four wheels. With four wheel drive systems you can even cause damage over time by using tires with differing amounts of wear. That is - you should replace all four tires at the same time on four wheel drive instead of two at a time. If your GLK is not 4matic then you don't need to be concerned about this.
If you GLK is rear wheel drive then it is ok to have different sizes front and back. The previous owner probably did this trying for a more aggressive appearance. One of the issues with such a staggered setup is that you can no longer properly rotate your tires. Inability to rotate can lead to shorter tire live due to uneven wear that cannot be moderated by moving the tires around to balance the wear. If all four tires are the same size then any tire can be mounted on any position to facilitate rotation and longer tire life.
Are your wheels original equipment or aftermarket? If OEM then they are probably all the same width and offset. If they are aftermarket then width and offset may be different and they may not all fit correctly on the front. Wider wheels up front may rub the fender in turns. It the wheels are different then it may be cheaper in the long run to continue with the bigger size in the rear.
If your wheels are all original and all the same width then I recommend using the original 235/50/R19 on all four corners so you can rotate for longer tire life.
Old Jun 23, 2019 | 03:18 AM
2009 GLK 220 cdi
All about tires depends on packets what you have...offroad packet can have 235/60/17 on front axle and 255/55/17 on rear axle...sport packet can have 235/50/19 front and 255/45/19 rear...GLK is very specific for this...I have offroad packet and have mixed tire size for summer tires and same size 225/65/17 for winter tires...no problem with anything and I already have 212 000 km on ODO...
Old Jun 23, 2019 | 10:55 AM
Mmr1's Avatar
2013 glk 350
What does the manual say? Glk is all wheel drive with limited slip differential, it’s not 4wd that can have locked differentials and bind the drivetrain. Different size tires should not hurt anything as it’s a free floating system. The brakes are what make the system work so well, the tire that slips is braked .
Old Jun 23, 2019 | 07:51 PM
2015 GLK350
Umm, not quite right. Regardless, a difference in tire diameters (and thereby circumference) will cause one tire and/or axle to spin at a different rate on a constant basis thereby increasing wear on the differential and/or transfer case. This goes for all AWD/4WD systems. This occurs regardless of limited slip or locking differentials. In fact, this generally wears limited slip differentials (which often use clutch packs) more than open differentials.
Old Jun 24, 2019 | 02:06 AM
2009 GLK 220 cdi
So use 255/45/19 and you are fine, diameter of the wheel is same like 235/50/19...
Old Jun 24, 2019 | 02:36 PM
andreigbs's Avatar
GLK 250
Stick to OEM size, that way you can properly rotate the tires as indicated.
235/50s if you have 19 inch rims. I'd suggest Michelin Premier LTXs, since that's what I run and they've been great so far.
Old Jun 24, 2019 | 03:14 PM
2009 GLK 220 cdi
She can have (very probably) OEM size for rear axle 255/45/19. Front axle 235/50/19...The diameter of the wheels is the same, rear wheels are wider, better look, better stability...
Old Jun 25, 2019 | 10:31 AM
andreigbs's Avatar
GLK 250
Diameter may be the same, but the extra width adds rolling resistance and even some aero drag. And if you rotate the tires as required, you'll have wider footprint up front which affects turning and braking. I say why bother?
Keep it OEM or 255/45s if you want wider, but use it all around.
