2013 GLK 250 P2006 intake manifold control runner stuck
Old Aug 15, 2019 | 03:48 PM
ChetTheTech's Avatar
2013 GLK
Hi Everyone,
I was driving (2013 GLK 250) the other day and this error code popped up. P2006 intake manifold control runner stuck bank 1. I've looked online and they sell repair kits for this error but only for v6 engines. I can't find anything on the GLK 250 with this error code. Does anyone know how to repair this on the GLK 250 or how much it would cost to repair at a shop? Thanks!
Old Aug 16, 2019 | 03:46 AM
GLK Super Fan's Avatar
GLK250 ML350
Originally Posted by ChetTheTech
Hi Everyone,
Funny story, my ml350 bluetec intake manifold just recently broke. Lucky i have a really good mechanic, he helped to me modify the swirl flap to open position, retune the vehicle so there will not be any cel. My car is still in the shop since i am getting my dpf scr egr delete as well. Just to fix the swirl flaps, my mechanic quoted me $1000? i cant remember the exact number, but he informed me it very labour intense to get to the intake manifold. It may be different story for glk250.
Old Aug 16, 2019 | 09:19 AM
andreigbs's Avatar
GLK 250
The 3.0L V6 Bluetec is a lot more complicated to get access to things, so I can understand the labor charges.
The 2.1L I4 Bluetec is probably easier to access and service, but the P2006 code isn't a common one that I've heard on these engines.
Removing the engine cover is easy enough though, so if you can take a peek under there and look closely at the intake manifold, that'd be where I'd start. There are swirl flaps inside the manifold that open and close as directed by the ECU. If/when the flap motor fails, you may get this CEL and code. From my reading, the flap motor fails so that the flaps are stuck open, so it shouldn't really result in anything negative apart from the engine light being on.
If you have a trusted Indy shop to take a look at it they might be able to confirm this. Hopefully they (or you) have a MB specific scan tool.
Old Aug 16, 2019 | 11:06 AM
GLK250 ML350
The default position for the flap motor is close since it spring loaded, unless there is excessive amount of carbon built up to prevent it close. The intake manifold is located on the right side of the engine under egr valve. There are few video online that people took apart the intake manifold to clean it. If you can get a mechanic to modify the swirl flap to stay open or remove it completely, that probably alot cheaper than replace the intake manifold since the parts itself it like $1300 cad. MB will probably want at least 2k for it
Old Aug 16, 2019 | 11:09 AM
GLK250 ML350
Check this video out. It not that complicated to get to the intake manifold, but i can see the shop at least charge u few hours of labor for it
Old Aug 16, 2019 | 11:52 AM
andreigbs's Avatar
GLK 250
I stand corrected, thanks.
Edit: in case you just want to slap a new intake manifold on there, here's one for $530 link.
Old Aug 16, 2019 | 02:12 PM
2013 GLK
Thanks everyone!,
The error code comes and goes. I like to try and do things myself whenever i can, but i like detailed instructions on how to do it so i don't accidentally break something else and learn the hard way. I've been looking everywhere for how to remove the manifold! Thanks so much for the video, I would've never found it since it's in Korean. After watching the video, it doesn't look too hard to remove the manifold, so i think i'm gonna go that route and clean out the manifold and hopefully that will fix the issue. Thanks for all the help and suggestions!
Old Aug 16, 2019 | 03:25 PM
C300fan2's Avatar
14 GLK 250
Thanks everyone!,
how many miles/km does your GLK have? Im curious to know how it looks when you take your apart. Maybe cleaning should be done at 100k or whatever.
Old Aug 19, 2019 | 06:59 PM
2013 GLK
There's 110k miles on it. I'll post up some pictures once its taken apart.
Old Aug 27, 2019 | 08:21 PM
2013 GLK
The video in the earlier posts tells you how to take out the easy part. Then at 45 seconds it skips passed the hard part and magically removes the manifold ... I tried to remove the EGR Cooler but looked to complicated without an actual manual. Can anyone point me in the right direction? Thanks!
Old Aug 28, 2019 | 02:53 AM
GLK250 ML350
I purchased the repair manual, which part you need help ? I can try to download the pictures and posed in here, or I can give u a link to pay $30 to download the manual
Old Aug 28, 2019 | 01:09 PM
2013 GLK
I need help removing the EGR component. If you can share that would be great. I would purchase the manual but after this repair it's going back up for sale. This vehicle has been nothing but problems for me. I like the way it looks and drives but i'm over it lol. Thanks!
Old Aug 28, 2019 | 04:13 PM
GLK250 ML350
hey man, i couldn't figure out how to download the manual and post on here. i took few pictures of the procedure, let me know if u need additional info
Old Aug 28, 2019 | 04:24 PM
GLK250 ML350
damn it, the pictures order is messed up
Old Sep 10, 2019 | 02:08 PM
2013 GLK
Thanks GLK Super Fan!,
This is a big help, the check engine light went away so i'm gonna leave it alone for now but it's good to know if i ever need to take it apart i have some instructions. I really appreciate it!
Old Sep 10, 2019 | 06:12 PM
GLK250 ML350
Did u end up opening up and clean it? How did u make the cel go away?
Old Sep 10, 2019 | 06:19 PM
2013 GLK
I didn't open it up and clean it. It just went away on its own. It's been about a couple weeks now, hopefully it stays that way haha...
Old Oct 31, 2020 | 02:40 PM
dzl_benz's Avatar
2015 GLK 250 BlueTec with AMG Sport package.
2015 GLK250 with 90,000kms... It's been a few weeks of well below 0C overnight and after one of the cold starts I got a "Pending" P200A code with OBD scan mode in my iCarsfot MBII scanner. It seems to be related to the intake flaps, similar to P2006 code. CEL wasn't triggered yet though. Neither I can detect a rough idle on a cold start or degraded performance. I haven't removed the intake yet for cleaning... will keep an eye on it for now.
Any other scanner I can use to diagnose this code further? ...besides buying STAR equipment
