Transmission service kit
Old Oct 22, 2019 | 05:53 PM
95viper's Avatar
2007 cls550
ECS has 4 kits for a 2010 GLK350. Three for trans without code A89 and one with the code. Example below. Where do I find this code? Can I validate by vin?
For vehicles With 7-Speed Automatic Transmission (Model 722.9xx) With Code A89 (Reduced Friction) - From Production Date: 6/21/2010
Old Oct 22, 2019 | 07:09 PM
B737's Avatar
2012 GLK
yes vin decode. you can also ask the dealer, they will go by vin and tell you which fluid your car takes. We used the ECS kit when we did two GLKs. I like the ECS kits, they are put together with all MB parts/fluids.
https://mbworld.org/forums/glk-class...ml#post7665910
Old Oct 22, 2019 | 10:22 PM
reesesboot's Avatar
2010 GLK 350 RWD
You can also inspect your trans pan to know with decent confidence which fluid your transmission uses. Red/blue or normal/low viscosity. Vin is your best bet (I only know this as mine is due in about 10k)
Old Oct 25, 2019 | 03:08 AM
95viper's Avatar
2007 cls550
Thanks guys. Vin decode says
datamb.com
Model year 2010
Engine272991 31 216152
Transmission722906 02 207733
Release Date2009-03-18
Delivery Date2009-03-18
No A89 code in options and the date is pre cutover.
Thanks everyone for the help!
