Keyless Go Issues (always locking when going near car or opening door)
Is this a normal issue?
If that doesn't solve your issue, you will probably have to go to the stealer and have them check out the antennas in the door handle. Do you have this problem on the any of the other doors or only the driver's door?
The only time I use the unlock button is on the rare occasion when the fob battery is getting weak and touching the inside of the door handle won't unlock it.
You basically have to insert your 4 fingers behind the handle and pull it open that way, instead of grabbing the handle with the whole palm enclosed around both inner and outer sides. Not intuitive, I know, but you get used to it.
