2011 GLK350 AC just 'stopped working'
anyone have any experience with this issue? No idea why it worked fine, then 30 minutes later, no longer cooling the air..
2011 GLK350, 97k miles
Using my $200 Actron, I showed NO codes stored.. Using my friend's VERUS D10, there were 16 random codes stored in the GLK. None of them were anything remotely AC-related. So after fiddling with it for awhile, I cleared all the codes, and restarted the car..
The AC started working.. The oddity is, that when you turn off the ac (push AC button, LED goes out) the AC remains on.. I now have to hit OFF, then hit FAN, if I only want the fan to blow without the cold.Even the VERUS Scanner shows ac remains in ON state, until I hit the OFF button.. weird..
Any thoughts or suggestions are appreciated.
I often found debris lodged in the screen down by the valve, which would explain yours being stuck "on". I'd bet you could clean it and re-install and it would work fine, although the valves are usually under $50 so I would just change it while I'm in there. I'm not sure if you can get to it on that platform, I have done some VW ones where I don't have to remove anything, it was facing down and I just removed it and recharged the system, super easy. On Rover/Jag products at my current job, I usually have to unbolt the compressor and rotate it in situ to gain access to the valve, it faces the engine block. MB was always a complete compressor replacement so I don't recall the position of the valve.
No AC in this charcoal-colored shoebox with black leather, leads to a very unhappy wife
I'll order the part today, and let you know results, once I get it all back together.
Side note: Do you have have any suggestions on possibly a decent scanner for the DIYer, that will actually read stuff worthwhile on an MB? My Actron is near worthless on the Benz..
EDIT: Ordered XC10606C "BMW Mercedes A/C Compressor Control Valve", $43.
But at any rate, Alldata said 3.3hrs.. LOL not for this fatboy.. More like 10. haha.So apparently theres a HUGE difference between the W204 and X204 4Matic cradles.. I could not use hardly a single socket.. 3 bolts for the AC, I had to use a 10mm ratchet wrench and pray I didn't strip the e12 bolts.. that was GRUELING..
But, I swapped the compressor control valve EX10606C was the part I used. Once it was all back together, I pulled a vacuum for about 20 mins, then locked it down at -20inHg. Let it sit for about an hour, and it stayed right there. Threw a couple cans in it and with ambient around 78-80F, I got it down to 58F at the vents. But it needs more, I think.. Low side was around 38, and high side was about 115.
Thanks again!
There should be a sticker somewhere under the hood that says the correct weight +/- a certain number. Go by that when filling a completely empty system.
