What is the Easiest way to drain coolant
Of note my 2013 - 65000 miles the voltage of the coolant was .17, good coolant is below .04, so most of you good folks need new coolant before it creates a leak
There may still be some residual old coolant left in various passages of the engine itself, but they will be "refreshed' by the new coolant as it flows once the water pump pushes it all throughout.
Make sure to set the heater controls to max heat, to ensure heater core and any other areas are burped of air.
For a proper job, some tools need to be purchased. Either the MB vacuum system or a bleeder. Use of a bleeder may remove the coolant but does not guarantee elimination of air pockets.
The coolant temperature is good (90c) but I got a P0128 so I doubt it is the thermostat.
I would like to replace the temp sensor first since i already got a brand new one anyways (worth the try).
Then if it still showing p0128 maybe I should drain it and replace all the coolant like you did.
