Ack! Dropped caliper thumb-wheel into oil filter housing
It's an orifice that is plugged (blocked off) by the oil filter's o-ringed snout, so oil doesn't travel thru that orifice to/from the oil filter. (post #24 shows)
https://mbworld.org/forums/glk-class-x204/817890-ack-dropped-caliper-thumb-wheel-into-oil-filter-housing.html#post8366570
The hole where the cable tie is in post 99 is not open to the filter. It is completely closed off by the plastic bit that sticks in the bottom of the filter. When you loosen the filter that plastic bit pulls up out of the hole and opens that passage to allow the oil in the oil filter housing to drain back into the sump. see the photo in post 10. If that were not true then the filter housing would be full of oil when you remove the filter, and it would make a huge mess.
The outlet from the filter into the oil galleries is the level above that one, blue in post 1 (also in post 24).
Review post 24 which has photos of the three openings and correctly describes how they work other than that it is correct that oil from the pump enters the filter under pressure through the yellow opening.
And, yes, you are correct, it's called a windage tray.
OP, if you can get your hands on a speedometer cable core it is strong enough and flexible enough that you should be able to wind it all the way down until it exits into the crankcase somewhere. (Find an older car in a junk yard, or, speedometer core replacement kits used to be common in any parts store) Put a slight bend in the end, then rotate it as you feed it in to help it find its way around the bends. It's sort of a moot point since you've already confirmed that oil pumped into this hole comes out in the sump. None of the pressure feeds would do that, at least not while you watched. It takes about 10 psi to make the oil flow and you'd need a column of oil about 25 feet high to generate that much pressure.
[Edit] I see the OP has already clarified some of these points while I was composing my response. I'll have to be faster next time!
3-4 inches after the magnet enters the orifice, it's sticking to something magnetically. I worked the tool gently so I could feel the feedback - it is sticking to whatever ... and if I move the magnet very slowly in an upward motion feels like bolt threads. Could it be the knurls of the wheel and it's wedged? Probably forcing the thought
Or, could it be a bolt? (Probably not; it's not likely there is a bolt passing through an oil drain passage.)
At this point, I think your options are these:
- Button it up and cross your fingers.
- Take the timing cover off.
- Sell it as is.
And yes, last night I spent an hour internet searching for photos of the front of engine with timing cover off / mating side of timing cover itself - nothing yet, so will keep looking
I have my doubts that that hole serves no purposes during normal operation, but I don't know for sure. As you know, oil has to be able to bypass the filter at high pressure. I don't know for sure how it's done on M276. My assumption was that one of the center holes is for oil to by pass the filter.
Literally spent countless hours to find this
If that passage went anywhere important, it would fill up with oil, at least temporarily, when you pump oil into it, but it doesn't.
The concern with the wheel, assuming it is lodged in the drain passage, is that it will end up on the windage tray and be flung by a crank throw against something it can damage, or wedge between the crank and something breakable, like the crankcase.
I'm outside the Houston area (in Magnolia), so I'm sure there's one or two shops worth their salt (?)
Unfortunately, I don't feel I'm at the point where I'm ready to tackle this disassembly, esp since I might not have the proper tools :/
Oh yes, I can do it, but the tools part is my downside
This has been going on way too long. We need closure.
Question : do I *have* to use the official Mercedes [gasket] sealant ? Maybe something from Loctite ?
I've read different opinions ... some say the Ford sealant is the way to go, some say Permatex, some say Loctite .
Thoughts?
Parts store didnt have the "black", but ordered and it'll be in 9am tomorrow, so will swap out then.
