power tap switched as well as always ON source?
Old Oct 25, 2021 | 02:12 PM
sblvro's Avatar
2020 C8, 2020 defender 110X, 2019 720S, 2014 GLK 350 4matic, 2015 escalade platinum, 2013 RRS HSELux
where can I tap wires to install my car cam? In the rear fusebox, it seems every fuse is switched. thanks!
Old Oct 25, 2021 | 04:29 PM
andreigbs's Avatar
GLK 250
Why would you want an always on source? I'm pretty sure all that will do is drain the battery.
What's wrong with switched on power?
Old Oct 25, 2021 | 06:52 PM
sblvro's Avatar
The Ithinkware needs both switched as well as always ON. It turns itself off if there is power drain and monitors the car for movement in parking lots while car is off.
Old Oct 26, 2021 | 10:21 AM
andreigbs's Avatar
GLK 250
You may just have to run wires from the battery if that's the case. Hopefully someone more knowledgeable chimes in.
Old Oct 26, 2021 | 10:32 AM
Mmr1's Avatar
2013 glk 350
My auto stereo shop used the front fuse box for both always on power and switched power. Call around it shouldn’t be more than 50$ With wires routed and hidden.
Old Oct 26, 2021 | 02:22 PM
John CC's Avatar
'17 GLS450, '14 GLK250, Grandpa's Roadster
Just a WAG, but, try fuse 46 or 61. Also, the spare fuse positions by 46 (47, 48).
Old Oct 26, 2021 | 02:32 PM
sblvro's Avatar
The rear fuse box?
Old Oct 26, 2021 | 09:36 PM
John CC's Avatar
Originally Posted by sblvro
The rear fuse box?
Yes, the front ones have lower numbers.
Old Oct 26, 2021 | 11:47 PM
MBKLUE's Avatar
Yikes:
You could use the Aux. battery in the trunk. Just use a small cable with inline automotive fuse holder when connecting to the Aux. Batt.
Old Oct 27, 2021 | 06:06 AM
sblvro's Avatar
Ok was able to fuse tap it! 91,42 and 40(is a spare) are hot or continuously ON. Of course the whole row of 43,44,45,46,47 are switched. Thanks all!
