GLK 250 115v rear outlet help
my 115v rear outlet stopped working after plugging in something with too much voltage. Does anyone know of a reset/relay switch? I've checked all related fuses and they are intact. Thanks in advance.
I have a small 120 volt air freshener (with the little glass bottle) that stays plugged in to mine. You know, the kind that plugs into a wall outlet in the house :-)
The inverter is behind the side panel near the plug. I didn't look inside to see if there was a fuse or anything. Did you confirm the big fuse in the panel in the spare tire well is good? Do you have any indicator light on the outlet itself?
You (like I) can probably find an inverter at a junk yard. It's an easy swap once you get the panel out.
