4matic mismatched tire
So I recently bought a 2013 GLK 350 4matic, although all tires were fairly new, i just noticed rear passenger side was mismatched and had a 55 aspect ratio intead of 50 like the other three. I immediately purchased another similar tire of the proper size but still mismatched. Will this cause damage to the 4matic system or anything else?
What is the whole number (e.g. 235/50-19) for each tire? It's the rolling circumference that matters, not the aspect ratio.
Odd Piggy (01-26-2023)
If the tire is the proper size, then the the mis match will be only in brand and/or tread pattern or possible load range. Tread pattern can have some braking and traction impact, but that is likely to be noticeable only in the most extreme conditions.
MBKLUE (01-27-2023)
OK, that will probably be fine. If it were my car, I'd probably buy two matching tires and put them on the back. Save the third one in case one of the others needs to be replaced prematurely.
Odd Piggy (01-31-2023)
