Not going into park
Old Apr 6, 2023 | 04:50 PM
Excorolla's Avatar
2013 Glk 350 4matic
Not going into park
Hi all,
Been lurking here and have been impressed and gained lots of knowledge.
Today the Glk does not go into park with the usual procedure(stop the car push button for park)
Shut the car off and it goes into park?
Any help or insight on what is going on would be greatly appreciated.
Sorry just realized I could have searched first.
Old Apr 6, 2023 | 07:21 PM
W205C43PFL's Avatar
Originally Posted by Excorolla
Hi all,
A couple of possible causes that I could think of at the moment:
1. Faulty brake switch
2. Faulty "park button" on the stalk
3. Auxiliary battery (if your GLK has one)
Old Apr 6, 2023 | 11:10 PM
Excorolla's Avatar
2013 Glk 350 4matic
I took a look at the auxiliary battery, it is dated from 2012. It has a one inch crack on the top, looks like liquid has leaked.
I ordered a new one. Thanks
P. S. I am new to being on a forum so please bear with me.
Old Apr 6, 2023 | 11:55 PM
calder-cay's Avatar
2014 GLK350 base model (active) ; 2001 E320 base (retired); 2001 Wrangler soft-top
We have a 2014 GLK and I recently replaced the Aux battery (took me five minutes in the auto parts parking lot).
I'm shocked you didn't get the "Aux battery malfunction" error message up on the dash , considering the shape the battery is in.
(I got the error, why I replaced ours)
Old Apr 7, 2023 | 09:13 AM
Mmr1's Avatar
2013 glk 350
The reason you may not have a “auxiliary battery “ warning is it is still good. It is an AGM, there is nothing that should leak out. Test it charge it , see what happens , use a charger with an AGM cycle
Old Apr 7, 2023 | 12:20 PM
MBKLUE's Avatar
Yikes:
The auxiliary battery has nothing to do with the parking brake. You can remove the aux. battery for a period of time, as I did (it was dead/defective), but it has no influence on the parking brake functionality.
Old Apr 7, 2023 | 01:17 PM
calder-cay's Avatar
Originally Posted by MBKLUE
The auxiliary battery has nothing to do with the parking brake ... but it has no influence on the parking brake functionality.
Might want to re-read the first post - the issue is their GLK won't shift into Park (as in Park, Neutral, Drive, etc) ...not an issue with the parking brake
Old Apr 7, 2023 | 04:11 PM
MBKLUE's Avatar
Yikes:
Not the perfect choice of words on my part but I fully understood what was written. A bad or removed aux. battery will have no effect on the functionality of the Park push button on the stalk.
Old Apr 14, 2023 | 10:29 AM
Excorolla's Avatar
2013 Glk 350 4matic
What next
Update,
Replaced aux.(10or11 years old). Problem not fixed.
Not going into park I found out is an intermittent problem.
I will try to replace the brake light switch(cheap enough).
Trouble finding location and maybe pictures or video on
replacement. Any help would be greatly appreciated.
thanks
R.D.
Old Apr 16, 2023 | 08:38 PM
BrianS17's Avatar
GLK350
I had this issue, and it was the gear stalk. It was replaced and now works fine.
2013 GLK 4matic
Old Apr 17, 2023 | 10:46 AM
Excorolla's Avatar
2013 Glk 350 4matic
2013 GLK 4matic
Thanks for the reply. May I ask the cost and was it fixed by you?
So far I have replaced the aux. battery(over due) and the brake switch(easy enough and inexpensive),
but now keep getting display message ESP inoperative. Will wait and see if it resets.
Old Apr 18, 2023 | 04:47 PM
BrianS17's Avatar
GLK350
Unfortunately it was repaired under a service contract, and they did not list the price. It also happened almost three years ago. I can tell you that it was a code U1420, there was apparently a TSB that they used to try and fix it but that did not work. So they replaced the part (Steering Column Module). I am writing what was on the Repair Order.
That is all I have.
Old May 8, 2023 | 12:39 PM
Excorolla's Avatar
2013 Glk 350 4matic
An update if I may on the GLK 350 issues,
Not going into park issue turned out to be intermittent. I used info gained here(thank you). Checked aux. battery, 10/11 years old, no aux. battery light on
dash. Installed new aux. battery on principle alone.
Three four days of daily driving later not going into park issue gone!
Almost the same time the above issue was solved, ESP warning on dash keeps coming on and resets after shutting down the car?
I replaced the brake switch with Mercedes part. The switch seemed to be adjustable as to the depth of how far away the switch is to the steel arm of the of
the brake pedal at rest(kinda hard to explain). I noted the position of the switch before removing it(quite sure it was original because of the date on it).
I put the new switch at the same depth. Drove it around for quite a few days. No self reset.
Frustrated and not a lot of time to fool around I brought the car to the local small auto repair shop(crossed fingers). Half a day later they
call, cars all set 51 dollars, said switch needed adjustment. WOW. No more ESP warning light for 7 days running so far.
Long winded wasn’t it!
thanks for listening
excorolla(Rich)
Old May 9, 2023 | 08:06 AM
calder-cay's Avatar
Quite the opposite, actually... many folks will benefit from the details you've provided for the fix. Many folks don't join a forum, but sit back and lurk , or because they've done a search to find a solution.
Thanks for the follow-up !
Old May 9, 2023 | 03:02 PM
W205C43PFL's Avatar
excorolla(Rich)
Thanks for providing an update on your vehicle, glad things are working well for you.
Old Sep 11, 2023 | 07:08 PM
Excorolla's Avatar
2013 Glk 350 4matic
It’s me again!
Not going into park issue came back again. Different this time as there is no warning lights(ESP) or other wise.
I installed a new brake switch as I had one left over from the last time this happened, no change. You have to stop
and either turn the key off and remove it or open the door to get it into park.
GLK is at an independent shop! Wish me luck(my wallet is sore already). Any ideas throw them at me.
Thanks for listening
Rich
Old Sep 12, 2023 | 01:25 PM
calder-cay's Avatar
Not going into park issue came back again. Different this time as there is no warning lights (ESP) or other wise.
In a previous post, you stated the switch was changed, and you ended up taking it to a shop and turned out the switch required adjustment.
So same issue happened - so you replaced the switch again ... maybe, it's an adjustment issue ?!?!
Old Sep 12, 2023 | 05:40 PM
Excorolla's Avatar
2013 Glk 350 4matic
This time not going into park is different in that no warning lights etc…I found out what the local shop did, they pushed it in all the way(that was there adjustment).
I did the same thing this time(still not going into park).
Today I picked up the GLK from independent shop. They pulled code U113B-29 (intelligent servo module, communication with the direct select lever has a malfunction) said they are not 100% it will fix the problem, cannot go forward with a maybe. They said part from dealer
is $825. They said it’s time to take it to the dealer.
Any more thoughts, help etc…before I call the dealer would be appreciated
Rich
Old Oct 13, 2023 | 06:51 PM
Excorolla's Avatar
2013 Glk 350 4matic
An up date:
The GLK came back from the dealer after fixing the not going into park issue. (OUCH).
They replaced the steering column module(control unit) plus the bolt and lock washer to hold in the steering wheel.
Total was $ 1761.
The said this is only the third time they had to replace this unit, day after my car showed up another(a year newer) car needed the same repair.
Wife does not like the car any more.
Rich
Old Oct 13, 2023 | 08:41 PM
300SE1993's Avatar
2012 S350 Bluetec, 2014 GLK250 Bluetec, 2026 E350 4Matic
An up date:
Total was $ 1761.
Rich
Glad you got it fixed, but I understand your wife's sentiment. You going to get another car?
Old Oct 13, 2023 | 11:31 PM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
I understand your wife’s fear of being stranded, but that part is unlikely to fail again for a long time. Ours decided it wouldn’t go into reverse intermittently. It hung on until we retired the GLK at 155,000 miles.
The newest GLK you can replace it with is a 2015. If you go newer, the GLC is the replacement. We went with a GLB. Compare carefully. Nothing quite like the GLK is available.
My wife put up with our older ML through a power steering pump, A/C repairs, transfer case output bearing. When the fuel pump stranded her, she said, ‘No more.”
