top side oil evacuator issues
Even if the vacuum doesn’t work, the GLK isn’t a hard vehicle to change oil on. It’s already fairly high off the ground. An additional 3-5 inches can be obtained with inexpensive low lift ramps from Walmart or Amazon. Or you can fabricate a pair from 2x12 lumber like I did. That will give all the work space needed. A closed top drain pan with a pour spout (also from WM or Amazon) will minimize mess and facilitate transfer to disposal containers.
I had the same problem with the GLS450; it was difficult to detect the bottom and the first try only netted about 5 quarts. Pull the tube up an inch at a time until you get it all, then mark the tube for future reference.
If the oil is warm and you suck it out soon after running the engine there won't be much of anything left in the sump. I resisted the idea at first, but now I find it a lot faster and neater.
If yours is a 250 I can measure the mark on my tube and let you know.
I also have the extractor in case I put a slight bit too much engine oil in to top it off for the vehicles.
I've also used it to extract fluid from the hydrostatic tranny on the zero turn mower
"you would weigh about four-thousandths of a percent less than at the average location on the planet" ... compared to Hudson Bay.
Obviously, @habbyguy 's gravity reference is about "un-level ground". But that goes without saying.
So they added a new enclosed garage - the problem is they didn't renew the "entryway slab" to be level , so vehicles in the garage are on a downward (or upward, depending on your viewpoint) slope.
There's no way in heck you're gonna check the oil level when parked in the garage. Check the 4 ft level I placed on the floor next to front GLK wheels (bubble is at extreme end)
In fact, I don't remember the last time I pulled an oil pan drain plug on any of my cars. That's not to say I forego safety inspections underneath from time to time; just that I drain oil via topside and don't worry about the 1-2% residual that I leave behind. There's other oil you leave behind when draining from underneath anyway, so don't sweat it or overthink it.
If you decide to farm out the labor and byo oil and filter, the Take 5 here will do it for $30. Call around or look online in your area.
