Odd vibration while turning
The issue: while my steering wheel is turned a minimum of 360 degrees in either direction, and while going forward or reverse at parking lot speeds, i get a new vibration? For lack of better words. The vibration feels as if it is coming from the rear differential but I haven't confirmed yet. This only happens while I'm turning the vehicle at slow speeds, hence the amount of steer angle. My steering wheel can turn lock to lock while stationary, so I don't believe any steering mechanism to be the culprit. There is absolutely zero vibration, shake, noise, etc.. while traveling at any speed, straight or otherwise. I am of course massively concerned of the issue being the transfer case and don't want to replace my transmission...
Is this detrimental to the vehicle? Is it suggested that i change front and rear diff fluid before having a transmission flush at my local MB indie shop? This vehicle is new to me and in immaculate condition despite having 140k on the clock. To my knowledge, the fluids are all likely original as I don't have service records. The car was an accident free one owner vehicle and I've put maybe 3k miles since I purchased it. The only service I've completed so far was an oil change, oil filter and air filter. Thanks for any and all input!!!
I'd suggest 36-38 all around. Make sure tires are stone cold first and use an accurate gauge.
As to the vibration/shudder you mentioned, I wouldn't worry about the transfer case just yet. But I would get all of the driveline fluids replaced (transmission, front diff, transfer case, and rear diff) and see what that's like.
The next thing I would do is check motor mounts and transmission mount. Most likely these kind of vibrations are caused by worn mounts. The transmission mount is easy to DIY and only costs about $75. The engine mounts are a PITA, so I'd leave those for last and only do them if you plan on keeping the car another 100K+ miles.
Guess what, it was pointed out to me, and I always overlooked it, but there's *also* a sticker on the fuel-filler flap! Ours shows 35f 38r for Normal Load, 38f 45r for Max Load.
Small vibration on forward low speed turns (parking). Also higher vibrational while low speed backwards and turning.
I already changed the transmission mount that was bad. The issue continues the same. Seems to come from the rear (diif?).
The mechanic inspect the car and said there is no visible mechanical issue. Also he said it is not wheel bearings. He will search for more information with some colleagues. I think next steps would be the diff fluid change. Transmission oil change (with the flush) uses around 10L of fluid and it is very expensive.
Any new information about this type of issue?
how did you solve yours
Others who have asked the same question, only have one post and disappeared (over a year ago) 🙂
I'd say the most logical response is @habbyguy 's reply. Pursue that potential problem.
Donor or used transmissions are very good and make sure to get it tested by your mechanic, this is about 6 months down the lane and the noise never came back
Lots of info on the parts and tools required in the video descriptions...
The job is not for the faint of heart, or for those whose tool kit can be lifted with two fingers... but it IS DIY-able (hey, if I can do it...). ;-)
https://www.youtube.com/watch?v=eZN35QDiBV8
https://www.youtube.com/watch?v=JNt68kNdFUU
