Engine oil pooling between filter cap and oil cooler
Turns out it was the outer o-ring that is around the oil filter housing ... and BE SURE the filter housing is tightened to the correct torque.
I'm NOT saying that my solution will fix your leak, but it's a fast and inexpensive "test" to see if it's the solution.
(i.e., just go to the local auto parts and buy a new filter, to include the o-rings).
For me, you could actually see the oil sputtering out (slightly) while the engine was running, although it was leaking out the backside, so was difficult to see (initially).
I even posted my problem and the solution out here.
EDIT: found my thread
https://mbworld.org/forums/glk-class...-not-good.html
Based on the pic, it looks like your cap is not screwed on all the way; I can see the rubber O-ring around the base of the cap. The plastic lip of the cap should be touching the oil filter housing; perhaps that's why yours is leaking?
This is a generic picture, but you get the idea:
If you put the o-ring up against the flange then it will not seal properly and the oil pressure will actually force the o-ring out of the space between the cap and housing.
I was POSITIVE I would see visible proof of a damaged o-ring, when I removed the oil filter housing. I was sure it would be cut or torn or oddly crushed in some way ... but it was NOT.
However, it was obviously "physically" flawed. What? When I screwed down the filter housing, there was zero tension. Why? Because the o-ring was circumferentially worn, but not particularly visible.
Physically, it was immediately obvious, after the new o-ring was installed... it took noticable physical force to screw the filter housing down, at the point when the o-ring met the aluminum cover, to its final seating.
Okay, I'm not trying to convince anyone, that my problem is @SAVZ 's leak. Just another experience to offer.
The design of the joint is such that the pressure tends to force the o-ring into the tiny gap between the OD of the cap and the ID of the housing. Until there is a mechanical failure, it should not leak.
Lucky for me I was able to find amother leak, looks like right underneath the washer fluid reservoir
Anyway, so I captured the image, then marked it ... check my image ... is THAT where you suspect the leakage is??
I know what I'll be doing this weekend, was hoping I wouldn't have to do this till it got a bit warmer.
