"Currently Unavailable" error
Old Feb 18, 2025 | 01:09 PM
sunnysky's Avatar
GLK350
Unhappy "Currently Unavailable" error
"Consult Operator's Manual "
Possible clue, "low voltage" but where? otherwise manual was no help.
GLK350 cluster%uck
GLK350 cluster
Should I try an OBD tester?
I looked at front fuse panel. Nothing unusual seen.
Temperature -10'C
Previously recent symptoms : random Transmission locked in Park after starting, corrected by restarting car. Possibly unrelated.
This means no {ABS, cruise control, anti-slip, or any other service with alert on. )
Old Feb 18, 2025 | 01:55 PM
trigital's Avatar
W213 All-terrain
Yes and without ABS I would be very careful as the steering could be hard also. Even if you will determine the defective part with a generic/chinese OBD tool, you will need a real scanner to make the repair.
Old Feb 18, 2025 | 02:15 PM
Mmr1's Avatar
2013 glk 350
Test battery and charge it.
Old Feb 18, 2025 | 06:16 PM
W205C43PFL's Avatar
GLK350 cluster%uck
GLK350 cluster
Temperature -10'C
Does indeed sound like a battery issue especially if the issue is apparent the colder it gets.
Old Feb 18, 2025 | 08:07 PM
sunnysky's Avatar
GLK350
Cool
I would expect a better indicator if the alternator failed.
The battery starting was certainly strong with a stiff engine.
So I expect 14.5V, but I'll check.
ECU & steering all 100% OK, rear window defogger OK, Fans OK so battery cannot be the cause.
Old Feb 18, 2025 | 08:43 PM
DenisMcG's Avatar
Veteran: Canadian Forces
2015 GLK 250 Bluetec
You definitely need to get the codes read, but with traction control and ABS not working it points to a possibly bad wheel speed sensor.
Old Feb 18, 2025 | 09:02 PM
Mmr1's Avatar
2013 glk 350
If you do not have an AGM battery likely the battery terminals and cables are corroded , they will need to be cleaned with a terminal brush not some liqued de oxidizer. AGM won’t output gas that corrodes terminals . A weak battery or alternator is possible . What is battery voltage sitting ? Charge it now if you can and get it tested free at most any auto parts store . They can also test alternator . If all test good you need a pro to find a fault .
Old Feb 18, 2025 | 11:36 PM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
I notice a check engine light also lit. Definitely get the low voltage addressed and get codes with an MB dedicated scanner.
Old Feb 18, 2025 | 11:45 PM
W205C43PFL's Avatar
That is good suggestion.
Old Feb 18, 2025 | 11:47 PM
W205C43PFL's Avatar
Yup, a scanner will help dearly.
