How to check oil pressure
Old Mar 22, 2025 | 08:58 AM
Mmr1's Avatar
2013 glk 350
How do you check oil pressure, will an obd dongle and Carly scanner do it? Is it in engineering menu? There must be a way as a MB shop would need to be able to do it.
Old Mar 22, 2025 | 02:28 PM
W205C43PFL's Avatar
Manually.
Old Mar 22, 2025 | 02:31 PM
W205C43PFL's Avatar
https://mbworld.org/forums/c63-c63s-...asurement.html
Old Mar 22, 2025 | 03:01 PM
Mmr1's Avatar
2013 glk 350
That is ridiculously difficult just to check pressure. I’m looking for the lazy way
Old Mar 22, 2025 | 04:26 PM
Silver Shadow's Avatar
2006 Alfa Romeo Brera, 2010 GLK350, 2018 BMW 640i GT, 1997 Subaru SVX, 2012 Moto Guzzi Norge GT8V
Pay somebody to do it. Can't get any lazier than that.
Old Mar 22, 2025 | 04:41 PM
calder-cay's Avatar
2014 GLK350 base model (active) ; 2001 E320 base (retired); 2001 Wrangler soft-top
WHY start a new thread related to this?
Your previous thread from Jan 5 🙂
https://mbworld.org/forums/glk-class...ure-gauge.html
Old Mar 22, 2025 | 04:50 PM
W205C43PFL's Avatar
Didn't know OP already has a thread but all good either way : )
Old Mar 22, 2025 | 04:52 PM
W205C43PFL's Avatar
OP, we also talked about oil pressure measurements in the oil pump solenoid thread: https://mbworld.org/forums/w212-amg/...ml#post9120480
Old Mar 23, 2025 | 05:14 PM
John CC's Avatar
'17 GLS450, '14 GLK250, Grandpa's Roadster
I have a ScanGauge, which can display most of the parameters of interest in the ECU. I asked their customer service about displaying oil pressure and got this response:
"Unfortunately, we do not have oil pressure available for your 2014 Mercedes GLK 250. An actual oil pressure reading is rarely reported through the ECU as most manufacturers only install a switch that reports when the pressure is low or high."
Old Mar 23, 2025 | 07:00 PM
calder-cay's Avatar
I jumped to the thread provided by @W205C43PFL and downloaded the PDF to my desktop, so I could look at the PDF on a large monitor (38").
That job connecting a pressure gauge to the dedicated plug seems easy enough and shouldn't take long.
EDIT !!!! ==========
I removed the photo showing our screw plug, because it turned out to NOT BE THE PLUG.
I went out into the garage with a smartphone, opened the hood, located the access plug (I think), and took the photo below. I've added an arrow pointing to what I think is the plug, next to the pulley.
Old Mar 23, 2025 | 08:46 PM
W205C43PFL's Avatar
I went out into the garage with a smartphone, opened the hood, located the access plug (I think), and took the photo below. I've added an arrow pointing to what I think is the plug, next to the pulley. I can see that plug looking from above the front grill.
I might jump to the other thread and ask the OP if they have done the job.
Thanks for posting this, it should help OP.
Old Mar 23, 2025 | 09:07 PM
John CC's Avatar
Which engine do you have? I don't think the document from the other thread is the right one. I think your plug is a little down and to the right from the one you are pointing to.
Here is the manual page for the M 272
File Type: pdf
Old Mar 23, 2025 | 09:11 PM
W205C43PFL's Avatar
Do you have the M276 guide, I believe OP has a M276 if 2012 model year?
Old Mar 23, 2025 | 09:13 PM
W205C43PFL's Avatar
never mind I think I found it, in the Oil Pump Solenoid thread, uploaded by forum member JettaRed: https://mbworld.org/forums/attachmen...720d1740874304
Old Mar 23, 2025 | 10:13 PM
calder-cay's Avatar
Ours is an M276 .... 2014 GLK350 Base RWD.
Our engine does not look at all similar to the one in your PDF, which is for 272, 273.
I even took photos of that "right side" and there's zero similarity... it was worth a try though 👍
Old Mar 23, 2025 | 10:24 PM
John CC's Avatar
Check the link in post 14, although the picture resolution is not so good. If I have nothing better to do tomorrow maybe I'll see if I can get a better copy. WIS told me it was a M 272. Hard to look anything up without a VIN.
Old Mar 23, 2025 | 10:31 PM
calder-cay's Avatar
Okay, great find !! That PDF is for M276. My assumption about the "screw plug" location was rwong.
Looks like my screw plug is even easier to access - just under and to left of oil filter housing. I'll no doubt have to remove the top plastic engine cover to see it. I'll bet it'll take about 15 minutes to attach an oil pressure gauge on our M276.
I'll check all that tomorrow after my early morning appt at the local VA Clinic (semi annual tests).
Old Mar 24, 2025 | 10:58 AM
W205C43PFL's Avatar
Sounds good.
Old Mar 24, 2025 | 11:15 AM
W205C43PFL's Avatar
Thank you : )
Old Mar 24, 2025 | 06:51 PM
calder-cay's Avatar
Okay, found a few minutes to spare, and removed the front upper plastic engine cover (or is it upper front).
See photo - took me 3-4 shots to get a good one. I also sprayed the area with electronic cleaner (for instant dry time).
I point to what I think is the screw plug, but I'm not confident, because the PDF is a bit grainy. I bumped the PDF to 200%, but still a bit blurry. Anyway, I think that screw is it, because the other two are different, and probably used to mount that plate
(M276 engine)
Old Mar 24, 2025 | 08:27 PM
W205C43PFL's Avatar
(M276 engine)
That might be it, you could ask forum member JettaRed for confirmation.
Old Mar 24, 2025 | 09:59 PM
John CC's Avatar
I found the right manual page and the resolution was no better, but, I think you've got the right one. The piece it screws into covers the oil passage from the oil filter to the block.
Old Mar 25, 2025 | 08:26 AM
W205C43PFL's Avatar
Thanks for confirming.
