Oil pressure gauge ?
Can a scanner Obd 11 like Carly work ? Kinda dumb MB gives us dumb folk zero option?
What about the issue on a recent thread where MB gives us possibly Zero pressure on cold startup that can be fixed to stop oil Starvation Noise ???
I think it’s a major issue
Idiot lights no gauges , no transmission dipstick, 9000 -10000? Mile oil change , no real volt meter gauge on dash that averages properly (unlike the hidden one in Engineering Menu) DUMB !!!!
I don't have access to my photo of my own dashboard, but found a website (loaded with ads, sorry) that seems to be a good resource for the kind of things you can do for around $20 (the kind of data only F1 had not that long ago). I really liked having that ability to monitor a lot of "interesting things" on a road trip.
Hello John C.
Unfortunately, we do not have oil pressure available for your 2014 Mercedes GLK 250. An actual oil pressure reading is rarely reported through the ECU as most manufacturers only install a switch that reports when the pressure is low or high.Regards,
Customer Service
Linear Logic LLC
My GLK is a 2011, but the vehicle shouldn't be an issue if it's got a working OBD port.
Keep in mind, the consensus is that you will NOT find "oil pressure" in the standard list of choices - you will have to add it using a custom added PID choice:
quote:
To access oil pressure data on a GLK 350 using Torque Pro, you need to select the "PID: Engine Oil Pressure" option from the available parameters within the vehicle's OBD-II data stream; typically, this will be listed as "PID 0x0A" or a similar identifier depending on your specific vehicle and Torque Pro configuration.
Key points to remember:
Accessing the data:
Once you've selected your vehicle make and model in Torque Pro, navigate to the "Sensors" or "Dashboard" section, and then search for the "Engine Oil Pressure" parameter.
Units:
The oil pressure will usually be displayed in pounds per square inch (PSI), but ensure to check your Torque Pro settings to verify the correct unit of measurement.
Normal oil pressure range:
For a GLK 350, a typical normal oil pressure range is between 20-60 PSI at idle and should increase with engine RPM.
Oil pressure must be sent to the main computer or how can MB diagnose properly. Maybe a poor featured scanner ! With no tech support.
John I downloaded the same app, I am confused how that dongle works with Car Scanner and Torque . I’m talking with tech support today , my negative Amazon review finally got a response! Not 10 emails ! And so far they say it’s not their email even though I got it off the app. A bit confusing , I asked how to check Oil Pressure so I’ll post back thanks guys 😆👍🏻
