GLK 350 2012 126,000 Trans Flush?
When I did my 722.964 trans I simply removed the pan, replaced the filter, installed a new pan due to the old pan rusting, then filled it back up. The fluid looked ok in my opinion so I didnt bother draining the TC. I did buy extra fluid and new TC drain plug in case I felt the need to drain it.
Just draining it from the pan I used 6 liters to fill it back up. I used an OE Filtran filter and Shell brand fluid. Installed new pan bolts, torqued to spec, and used my obd scanner to fill it to the proper level.
FWIW, here's a video I did on the process, showing you everything you need (including fluid - I suggest OEM fluid - that's one thing I tend to never compromise on, assuming that the manufacturer of the transmission knows best how to keep it running for the longest possible service life)... I include all the info you need in the video description (click on the video title in the box below to access the description)...
And no, you won't hurt a transmission doing a fluid change. It is theoretically possible for it to nudge an already damaged transmission into failure, but if it does that tranny was a goner anyway. A transmission fluid change is the best thing you can do to a car with an automatic transmission to keep it on the road for many more years.
2) Do not use Shell branded fluid UNLESS It is the proper SPEC: 236.14
But call Mercedes and CONFIRM the SPEC
APPROVED OILS:
https://operatingfluids.mercedes-benz.com/sheet/236.14
If you cant do it yourself, Mercedes or a proper EURO shop will do it but It will be about 500-800$
Then goto:
And make sure you ONLY use the CORRECT fluid!
Im not sure if 5 quarts will be enough. I didnt drain my torque converter and ended up using 6 quarts of new fluid, drained out a little when setting the proper level.
Be sure to follow the torque specs for everything. Ive read stories of people snapping the transmission pan bolts, they arent torqued that tight.
one of the main reasons I bought a mercedes specific obd scanner is to read transmission fluid temp when replacing the fluid.
