Rear left reluctor ring
Old May 23, 2025 | 10:18 AM
Empirerevs's Avatar
2013 Glk350 4matic
2013 glk350 4matic
A week ago my car threw abs and esp lights on. Read codes and said left rear wheel speed sensor so I replaced that. Still had the problem, checked the reluctor ring and it’s terrible rusty/possibly broken. Issue is I can’t seem to find this part anywhere. I am under the impression that the rear ring is toothed but everything I find is smooth and I can’t imagine they are interchangeable
Last edited by Empirerevs; May 23, 2025 at 10:49 AM. Reason: Didn’t include my car lol
Old May 23, 2025 | 10:42 AM
Mmr1's Avatar
2013 glk 350
Ok I’ll put on my magic hat and guess at the car you have . It’s a Toyota Camry 2005, am I correct 😂😂😂😂😂
Old May 23, 2025 | 10:48 AM
calder-cay's Avatar
2014 GLK350 base model (active) ; 2001 E320 base (retired); 2001 Wrangler soft-top
You don't see the vehicle description in the OP's Profile ?? The Profile exists so folks don't have to always type their vehicle details in ever post
Old May 23, 2025 | 10:49 AM
calder-cay's Avatar
Found at FCPEuro... Mercedes ABS Reluctor Ring - Genuine Mercedes 2303570182.
Also found a post, confirming part #
https://mbworld.org/forums/glk-class...-abs-ring.html
Also known by MB as a Pulse Ring, at mbparts
https://mbparts.mbusa.com/oem-parts/mercedes-benz-pulse-ring-230357018264
Old May 23, 2025 | 10:56 AM
Empirerevs's Avatar
2013 Glk350 4matic
https://mbparts.mbusa.com/oem-parts/...g-230357018264
thank you I guess I’m just confused because it seems to be toothed but that one is not
Old May 23, 2025 | 11:06 AM
calder-cay's Avatar
clearing duplicate Reply
Old May 23, 2025 | 11:10 AM
calder-cay's Avatar
Might want to check this video.
Bad magnetic - good read (below):
https://mbworld.org/forums/e-class-w212/901320-these-dreaded-abs-esp-lights-2.html
Old May 23, 2025 | 11:50 AM
Mmr1's Avatar
2013 glk 350
So I’m supposed to do work to look up his vehicle! Na
Old May 23, 2025 | 02:18 PM
DenisMcG's Avatar
Veteran: Canadian Forces
2015 GLK 250 Bluetec
There is no work. It is written right under the user name to the left.
Old May 23, 2025 | 02:35 PM
Empirerevs's Avatar
2013 Glk350 4matic
https://m.youtube.com/watch?v=Xsqy8TeEcA8
https://mbworld.org/forums/e-class-w...-lights-2.html
you’re goated, thank you my friend
Old May 23, 2025 | 04:06 PM
Silver Shadow's Avatar
2006 Alfa Romeo Brera, 2010 GLK350, 2018 BMW 640i GT, 1997 Subaru SVX, 2012 Moto Guzzi Norge GT8V
I bought mine on Amazon 2 years ago, still working great (touch wood). $16 CAD.
They are smooth.
Old May 23, 2025 | 07:16 PM
JohnnyC's Avatar
2015 GLK350 & 2020 C300
If you choose to tackle this job you can dismount the wheel bearing with a thin E12 and the spindle doesn't hafta to go off. You should be able to knock the ring off after that. You'll also need a big torque wrench that goes to 350Nm.
