Glk 350 transmission
Has the transmission ever been serviced or fluid changed?
As long as the new transmission is the same generation and same options, you should be able to swap the electronics and make it work.
The truck only has 148k on the dash the transmission is from a 2012 e350 722.9 plus same as mines with about 95k miles on it but I’m pretty sure my torque converter is what went bad because the car is drives me and doesn’t slip getting in gear it slips trying to get the power to the transmission
I changed at 120k km, at 150k km did it again and the oil was black, lots of sediment at the bottom of the pan.
Did another flush at 170k and oil was black again with sediment, but better. I assume there was a lot of varnish/build-up in the transmission that was still getting cleaned out.
It's too bad they didn't design the transmission pan for an easy drain... Weistec makes a replacement pan that is much improved, worth the upgrade if yours is rusty.
Also, on the 4Matic, the "transfer case" (really more of an integral part of the transmission) shares the fluid as well, though it doesn't change the total capacity much.
