ESC currently unavailable
Old Aug 12, 2025 | 04:44 PM
Shouston1's Avatar
2010 mercedes-benz glk
Hello everyone, I have been having issues since July, my ESC currently unavailable see operator's manual popped up and my truck loss power. I turned it off and back in I got to work & on the way home it did the same thing. My mechanic changed the coils/spark plugs , then he said it was the secondary air injection pump so I replaced that, then every other day it would continue. He claims he checked all the sensors then said my alternator was bad so Saturday 8/9/2025 we replaced it today after not driving all yesterday it did the same thing ESC currently unavailable. Someone ple
Please help me
Please help me
ase offer me some advice. This issue has costed me my job
Old Aug 12, 2025 | 04:55 PM
John CC's Avatar
'17 GLS450, '14 GLK250, Grandpa's Roadster
Find a new mechanic. He's shooting in the dark. ESC relies on things like steering angle sensor, yaw sensor, wheel speed sensors, etc. If it posted the warning it must have stored some data.
Old Aug 12, 2025 | 05:00 PM
Shouston1's Avatar
Thank you for your reply, we checked all the sensors I have to investigate why this continues to occur
Old Aug 12, 2025 | 06:50 PM
Silver Shadow's Avatar
2006 Alfa Romeo Brera, 2010 GLK350, 2018 BMW 640i GT, 1997 Subaru SVX, 2012 Moto Guzzi Norge GT8V
Nothing he did has anything to do with the problem. ESC= electronic stability control.
Get a new mechanic to read the codes with the proper equipment. More than likely it's an ABS wheel speed sensor or such.
Old Aug 12, 2025 | 06:56 PM
Shouston1's Avatar
Thanks for these replies as I previously stated we already checked the wheel sensors checked codes etc if anyone has a clue what else besides what I have already stated please let me know
Old Aug 12, 2025 | 07:03 PM
The reluctor ring on the rear axle. I replaced mine a few years ago following the ESC warning. Get it from Amazon. MB wants you to buy the whole axle.
Old Aug 12, 2025 | 08:18 PM
John CC's Avatar
Your mechanic changed the coils/spark plugs , then he said it was the secondary air injection pump so he replaced that, then every other day it would continue. He claims he checked all the sensors then said the alternator was bad so Saturday 8/9/2025 you replaced it today after not driving all yesterday it did the same thing.
None of that helped, so why do you think the sensor tests and code readings were worth any more?
Old Aug 12, 2025 | 11:59 PM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
If that display is on the instrument cluster there is information stored in the ECU memory about it.
Does your user name Shouston1 have anything to do with you being located around Houston TX? If so, let me know if you want me to give you some locations of competent independent techs who can resolve this. If you don’t want to publicly disclose your location, PM me.
Old Aug 13, 2025 | 04:07 AM
Shouston1's Avatar
I live in Arizona. I will check today at Aamco to see if its loose wires like you suggested
Old Aug 13, 2025 | 04:56 AM
Mmr1's Avatar
2013 glk 350
Dam , that’s nutzzz, that guy is a crook or a moron or both . I’ll bet you just spent (got suckered) 1500$ or more for absolutely nothing of relevance to your problem . I’d be interested in knowing his logic behind what he did. I can’t think of anything related to ESC . I’ll bet you got all cheap Chinese parts also . He owes you for that scam ! Take that bs guy to small claims.
Was it misfiring - running rough? So why the plugs and coils ? And who made the parts ? Why the alternator? Was a warning light on or dead battery ? I’ll bet no, and you started it! What about that pump he replaced that gas absolutely noting to do with. esc. And what pump was that ? I think you just got scammed.
the best part is I’m no mechanic , and I see the scam ! I really question parts quality or if the things were done!
Old Aug 13, 2025 | 05:52 AM
Shouston1's Avatar
Unfortunately you are mistaken I have OEM parts, I needed 3 coils and no I didn't pay $1500 for labor , I didn't have to pay labor at all. I now noticed numerous individuals on this forum are bored, disgruntled and have horrible spirits. No thanks to the thread and internet mechanics the issues have been addressed.
Old Aug 13, 2025 | 06:18 AM
Mmr1's Avatar
2013 glk 350
I just came back here to state this must be a dumb *** troll! But now you repost new barf! You came here crying to us, what the mechanic did to fix the ESC. Which did not work. Which nothing he did was related to the ESC! . You’re the one with the problems , they are not Glk related. A little bit of entertainment is always good.🤪😂
Old Aug 13, 2025 | 06:29 AM
Shouston1's Avatar
I wasn't crying at all, I asked for suggestions on ESC and told all what was recently repaired. My only problem is here is you !!! There was no reason for your condescending demeanor. If your entertainment comes from a mercedes-benz forum you have deeper issues.
Old Aug 13, 2025 | 06:36 AM
Shouston1's Avatar
Also thank you for all who sent private messages!! I 100% see exactly what you were referring to as far as the elderly person who continues to comment disturbing comments. R8 your suggestion worked yesterday after going to Aamco and yes nothing mentioned was helpful just spewing insulting displaced rage
Old Aug 13, 2025 | 10:39 AM
John CC's Avatar
So, what was the fix?
Old Aug 13, 2025 | 10:43 AM
Shouston1's Avatar
My apologies, in my situation it was the reluctor ring
Old Aug 13, 2025 | 11:00 AM
John CC's Avatar
Odd: the forum index says there's a new post to this thread by Shouston1 at 10:43, but when I choose "View first unread" it takes me to post 1, and when I go to the end it shows the last post as mine from 10:39. I wonder what will happen when I post this reply at 11:00?
Curiouser and curiouser .. One of my posts (after this one) also vanished.
Old Aug 13, 2025 | 11:03 AM
Shouston1's Avatar
I am not sure what that means.
Old Aug 13, 2025 | 12:07 PM
I had some glitches this morning also. I'm receiving emails that Shouston 1 has posted and I can read his posts in the email. They do not appear on the forum.
Old Aug 13, 2025 | 12:13 PM
Shouston1's Avatar
these 2010 glk are giving multiple issues hopefully you get it done
Old Aug 13, 2025 | 07:50 PM
Bill F's Avatar
2013 GLK 350 4 matic
If an email is sent out and the post is later deleted it can appear strange. Not as strange as his mechanic.
Old Aug 13, 2025 | 10:06 PM
John CC's Avatar
Were the posts of a nature that may have been deleted by a moderator?
Old Aug 14, 2025 | 06:29 AM
I had considered that. You may be right.
