235/60/20 tires on 2011 GLK350 RWD?
Old Nov 2, 2025 | 07:39 PM
John CC's Avatar
'17 GLS450, '14 GLK250, Grandpa's Roadster
My owner's manual says the 20" rims are 8" wide (8.0 J x 20 H2)
The rim is probably marked thusly.
Old Nov 2, 2025 | 07:46 PM
Silver Shadow's Avatar
2006 Alfa Romeo Brera, 2010 GLK350, 2018 BMW 640i GT, 1997 Subaru SVX, 2012 Moto Guzzi Norge GT8V
Originally Posted by Merciful
how?
I have 255 on stock rims, so no problem for 245.
Old Nov 2, 2025 | 07:51 PM
John CC's Avatar
I would think that is pushing it, since 8" is the minimum width for the 235's. When the rim isn't wide enough the tire will be pinched at the bead and the tread won't want to lay flat on the road and will wear excessively in the center.
Odd... I just looked up a 255/45-20 Continental tire and it also said 8" - 9.5" rim width. Both this and the 235 tire list 8.5" rim as the width the tire was measured on. The tread width is almost a full inch wider.
Old Nov 2, 2025 | 07:56 PM
3 years of use at 8 months per year and wearing perfectly. I'll likely get another 2 years of use out of them. The tire shop had no problem or complaints about installing them.
Old Nov 2, 2025 | 09:04 PM
Merciful's Avatar
GLK350 2011 RWD
the www.wheel-size.com says that GLK pre-facelift was equipped with 8 different tire/rim sizes and only one of the 20" rims is 8J. How could your manual be so single-valued? Mine doesn't have my exact tire size, it contains only general values.
My wheels that I already posted here look exactly like wheels of those guy in thread GLE wheels on GLK X204. As he says they are 8.5J, so mine are very likely the same. If my wheels are 8.5, I guess I am free to install to them everything in between 8.5" and 9.5" width. Am I right?
Old Nov 2, 2025 | 09:14 PM
John CC's Avatar
Mine's a 2014.
Old Nov 2, 2025 | 09:20 PM
  #32
Merciful's Avatar
GLK350 2011 RWD
Overall, the aim of this thread was to collect GLK owners experiences with different tire sizes. So far I found these threads:
245/40/20 #1
245/40/20 #2
245/50/20
255/45/20
It would be nice to get confirmation on more options.
Old Nov 2, 2025 | 09:23 PM
  #33
Merciful's Avatar
GLK350 2011 RWD
Mine's a 2014.
I put in the thread title that mine is 2011, so 2014 is not relevant here.
Old Nov 3, 2025 | 01:51 PM
  #34
John CC's Avatar
You asked and I answered. If it wasn't relevant, why did you ask?
Good luck in your search for cheap tires that don't rub.
Old Nov 3, 2025 | 02:36 PM
  #35
John CC's Avatar
By the way, are you aware that the 20 inch options in your manual are both staggered fitment? It would be a good idea to confirm what size wheels you have before moving on. Check two, and if they are the same, check one more.
Old Nov 3, 2025 | 07:13 PM
  #36
Merciful's Avatar
GLK350 2011 RWD
as I said before
so looks like my wheels parameters are:
20" x 8.5": 235/45-20
BOLT PATTERN 5 X 112
OFFSET 0.45
Old Nov 3, 2025 | 07:28 PM
  #37
Merciful's Avatar
GLK350 2011 RWD
also, in addition to the below non-standard sized ppl already tried on GLK
I found additional one https://mbworld.org/forums/glk-class...ml#post6139723, and it looks awesome judging by photos. So now we have this list of acceptable tires on stock GLK 20" rims: 255/35/20 is also good
245/40/20 #1
245/40/20 #2
245/50/20
255/45/20
255/35/20
Old Nov 3, 2025 | 07:34 PM
  #38
Merciful's Avatar
GLK350 2011 RWD
Turn the steering full lock then see how much clearance you have, then
I turned the full lock, here how it looks like. I can put the biggest finger in the gap, so by avg estimation there is 1 more inch possible to put in. What do you guys think?
