GLS Class (X166) Produced from 2016 to 2019
How to find out the terminal of battery and disconnect it?
Old Apr 24, 2018 | 02:41 AM
bylife's Avatar
GLS350d s
I will leave my GLS 350d inside garage for two months. I would like to disconnect the negative terminal connection, but do not how to find it and how to disconnect it.
I will appreciate it if someone can show me how to do, it will be better with photos.
Great thanks.
Old Apr 24, 2018 | 12:46 PM
redcarrera's Avatar
'21 M5Comp, '17 GLS450,'17 Range Rover, '08 Carrera 4S
You might consider using a battery tender instead of disconnecting the battery. You'll be unhappy when you find our where the battery is.
Old Apr 24, 2018 | 02:47 PM
c4004matic's Avatar
17 E43; 21 GLS580
+1
Old Apr 26, 2018 | 12:49 AM
Peter R.'s Avatar
W126-500SEC
Great thanks.
I could do you a picture, but since your steering column is in the wrong place it wont be the same as mine.
Just in case they mirrored it : open the hood (or bonnet, or whatever you call it) and look at the top of the inside of the inner wing : you should see a metal pin there, about 4 cm long and 1 cm in diameter : that's the earth connection for the jump starter cables. There's a think black wire attached to it. Follow it straight back inder a plastic cover (upper right corner of the engine compartment) ant it shouuld be there.
That said, disconnecting the battery is a bit of a last resort. Use a conditioner when at all possible.
Pete
Old Apr 26, 2018 | 02:58 AM
bylife's Avatar
GLS350d s
thanks for all of replies. I will buy one battery charger and ask the dealer for the right connection.
Old Apr 26, 2018 | 08:58 AM
mrmotoguzzi00's Avatar
Don't buy a cheap battery charger.... Battery Tender is a known good brand.....
Old Apr 26, 2018 | 03:32 PM
redcarrera's Avatar
My dealer quoted US$ 180 for a "Mercedes" battery tender.
I bought a Battery Tender Plus on Amazon for US$ 45. Your choice.
Old Apr 26, 2018 | 03:45 PM
yup like the choice
Old Apr 26, 2018 | 11:20 PM
c4004matic's Avatar
17 E43; 21 GLS580
Originally Posted by mrmotoguzzi00
yup like the choice
CTEK makes all the european oem trickle chargers, 60 bucks on amazon. It also reconditions if necessary use it overnight every 6mths and you never have to worry about a dead battery. Better yet, since it desulfates yhe battery it can more yhan double you battery life. Worth every penny. Furrhermore, since it a general purpose model you can use it on any battery type.
Old Apr 27, 2018 | 02:03 PM
rominl's Avatar
16 GL550
^^ this. ctek manufactures the battery tenders for a lot of oem
