GLS 550 spins to lose the control in rain
I was driving my 2019 GLS 550 with a mileage of 16500, couple days ago on the highway way, with cruise control around 70 mile/hour, same as the speed limit. Suddenly, the heavy rain started. I felt the car was trying to brake down by itself for seconds, then the car started to spin and slid off the road into the ditch between the high ways. I got back to the high way and drove the car at 60 miles per hour in the rain without cruise control only for couple of miles before the car spun again in the same way as before, and slid off the road. Thanks to God, the car and me were okay except some scratches and tears to the back of the car.
I have driven different cars for more than 20 years for about 200k miles without any accidents. I drove in heavy rain or snow before, but nothing like this happened. What’s wrong with this car? Please help me with your thoughts and suggestions.
Thank you very much and have a nice evening.
The following 2 users liked this post by Lodi:
Andrew Porter (11-27-2022),
GLSsSuck (02-05-2023)
The obvious and only question is: what is your tread depth? Trying to drive on rain with slick tires is a fool’s errand.
SVDNN (02-14-2023)
E450 wagon, C43 AMG Cpe, C43 AMG Cab
This sounds strange. Yes, tread depth is important as is tire pressure. But how bad can the tires be at 16,000 miles? Check anyway. The other issue, and I know you stated that this occurred with cruise on and again with cruise off, you should never use cruise control in any type of inclement weather...like rain or snow or wet roads. That's looking for trouble. Just curious...was your lane departure system engaged?
Probably hydro planing.
If tire contact patch is huge this can happen more oftgen then not.
Based on tire size you posted that is realy wide patch and tire OD.
11.6" wide by just over 30"OD
Check your air pressure is to spec
Maybe get better wet weather tires...
I drove a 2010 GL350 for 10 years on the Goodyear run-flats (OEM tires) and never had any issues with rain or snow. In fact, in snow, I was often able to go when others in AWD couldn't. I drove in lots of heavy rain with no issues. If your vehicle is spinning out of control your tires are shot and/or you're going too fast for conditions. I would never use cruise control in bad weather. I only have a few hundred miles on my GLS580, so can't really comment much on how it does in bad weather but don't expect it to be any worse, especially with all the new tech on the GLS that didn't exist on my GL.
I check the trades, which looks good to both front tires, but quite bad to the back tires especially the one to the left back. My next maintenance is due in August. During my last maintenance and also the first one, I was told everything was fine. Why are the back tires worn out so badly for such a mileage?
MelissaC (05-02-2024)
Yes, the lane departure warning system was on for the both times. Actually, my first thought was that somethings went wrong with the system. I felt the system was overreacting and trying to brake too much and cause the car to lose the control. Do you agree with that?
Thank you all so very much for your educated comments.
Thank you very much.
There is your problem worn rear tires.
They wear fast since they are SPORT high dry traction tires probably which means they do not last very long
Is it possible something wrong with the wheel alignment to wear rear tress fast? I was impressed the front tires wears out faster usually.
Lodi, I am wondering if your car's lane departure assist may have been inappropriately applying the brakes, causing your car to lose control. I know the lane keeping assist will jolt my car when I drift in a lane. Fortunately I have not experienced this while driving on slippery wet roads yet, but have wondered what the effect of that 'sudden jerking' would have if driving on snow or rain.
Also with rain the lane keeping assist may have difficulty sensing the actual lane markers, applying the brakes when not needed.
So yes, get an alignment when you replace the tires. And don’t be surprised if you have to replace the rear brake pads much more often than the fronts, which is counterintuitive.
I would also check alignment as well as tire pressure. One more thing: if you used on of those tire dressing products, it can make your tires very slick.
2020 GLS580, 2020 Corvette Z51
How are the tires worn, evenly across tread? more in the middle? at one or both edges? If they are worn in the middle primarily your tire pressure is too high. 42 sounds like the pressure for full load. My GLS580 tire pressure for normal load is 29 lbs.
I usually keep the tire pressure about 40-42, which was on when I got the new car from my dealer. According to the tire pressure list on the fuel lid, 40-42 are little bit higher.
Should we let MB know about our suspicions and let them check it?
Thanks a lot.
