2017 GLS450 - P0505 & P0302
I recently got the following issues from my 2017 GLS450 - 115K: A very rough lumpy idle, white smoke from the exhaust and the engine will not rev smoothly at any speed. An OBD tool reports, the following faults:
P0505 - Idle Control System Malfunction
P0302 - Misfire in Cylinder 2
P0305 - Misfire in Cylinder 5 (this comes and goes?)
P300 - Random Multi Cylinder Misfire.
Reset them will not work at the codes are stating the are "PERMANENT" - I guess they will self purge once the issue is no longer present!
I have replaced all the plugs and switched the coils that are reporting a misfire, but the misfire stays at Cylinder 2, Cylinder 5's misfire comes and goes?
Can anyone help with the following: some sites state to clean / replace the IACV - where is it, doe's this vehicle even have one? Will cleaning the trottle body help?
Any help will be greatly appreciate....
Thank you
Sam
- bubbles in the coolant reservoir?
- chocolate milk film/sludge under the oil fill cap?
- sweet smell from exhaust?
- coolant level dropping over time?
- "washed" piston face or spark plug?
- low compression on any cylinder?
- bubbles in the coolant reservoir? - NO
- chocolate milk film/sludge under the oil fill cap? - NO
- sweet smell from exhaust? - NO or not percievable by me?
- coolant level dropping over time? - NO - coolant look s normal with no signs of level change of contamination
- "washed" piston face or spark plug? - Replaced plugs but old plug@ cylinder 2 had a cracked and broken insulator and looked grey.
- low compression on any cylinder? - TBA
Sam
Sometimes that is caused by destructive detonation, (or someone dropped the plug and used it anyhow) which can cause all sorts of other problems in that cylinder. I'd want to do a boroscope inspection on that one.
