GLS Class (X166) Produced from 2016 to 2019
No boost?
Old May 9, 2026 | 01:28 PM
AMGonFire's Avatar
2012 c63 AMG, 2011 GLK 350, 2019 GLS 450
No boost?
My 2019 gls 450 isn’t making any boost. Just running on an all motor car. It’s very slow but drives without hesitation miss fire or any issue. It can get up to any speed just takes a bit. Someone would just think the car is very slow. There is no check engine light or stored code. I don’t know what this could be. Any thoughts?
Old May 9, 2026 | 02:15 PM
John CC's Avatar
'17 GLS450, '14 GLK250, Grandpa's Roadster
Originally Posted by AMGonFire
My 2019 gls 450 isn’t making any boost. .... There is no check engine light or stored code.
That hardly seems possible...
Old May 9, 2026 | 04:13 PM
AMGonFire's Avatar
I agree. However that is what is happening. Live data showing zero boost. Can get up to speed and drive around fine just takes time with zero boost. Running on motor only. When I scan it says no codes. I’m leaning toward boost sensor but I would think it would trigger a code.
Old May 9, 2026 | 04:27 PM
W205C43PFL's Avatar
OP, I saw your other post in another thread, the M256 usually don't have the failing check valve issue, that said, the model's forum you replied in (the c 43) there is a thread going with a "low boost issue" https://mbworld.org/forums/c450-c43-...-behavior.html that you can read but unlikely related to what you have. When you said no stored code, did you use a scanner capable of reading MB codes and not just something generic?
Here is yet another model:
https://mbworld.org/forums/w213-amg/...hing-else.html
https://mbworld.org/forums/c63-c63s-...ull-boost.html
Old May 9, 2026 | 06:02 PM
serb's Avatar
2017 GLS 450,Bmw Z4 35i
check intake hoses
Old May 9, 2026 | 07:48 PM
W205C43PFL's Avatar
Originally Posted by serb
check intake hoses
This.
Old May 18, 2026 | 05:43 PM
W205C43PFL's Avatar
Correction: I just realized this is a 2019 GLS 450 so it has the M276, it does not have the M256. I thought I was replying in the V167 sub-forum.
That being said... OP, any update?
Old May 18, 2026 | 06:09 PM
AMGonFire's Avatar
im at a loss. I replaced the boost sensor. Waiting on delivery of that vacuum check valve but that wouldn’t be the issue. Checked for leaks and used a scanner to check the operation of the waste-gates and they both operated on command from the scanner. So far no luck. Might have to take it to the pros.
Old May 18, 2026 | 07:29 PM
W205C43PFL's Avatar
Here are more options:
https://mbworld.org/forums/e-class-w...-0tt-m278.html
Old May 18, 2026 | 08:36 PM
serb's Avatar
smoke test the hoses bro
Old May 19, 2026 | 08:02 AM
W205C43PFL's Avatar
This as well.
Old May 19, 2026 | 10:35 AM
AMGonFire's Avatar
Thanks all I will update what it ends up being
Old May 19, 2026 | 10:40 AM
W205C43PFL's Avatar
Sounds good OP, sounds good.
Old May 19, 2026 | 11:14 AM
John CC's Avatar
Can you monitor the position of the wastegates? If they are closed and you have no boost then it sounds like you have a turbo issue, or a severely restricted intake. Try monitoring intake manifold pressure to see if it acts like a normal normally aspirated engine.
I once fixed a turbo performance issue by removing a shop rag from the intake...
Old May 24, 2026 | 08:55 AM
Petro55's Avatar
2016 GL 450
I just replaced passenger diverter valve. It had a tear in the yellow rubber. I also was noticing real slow acceleration from start.
I also cleaned my MAP sensor, it had some oil residue in it.
Old May 25, 2026 | 08:14 AM
W205C43PFL's Avatar
All good now?
Old May 25, 2026 | 09:05 AM
chassis's Avatar
2017 GLE350 4MATIC
No boost with no codes? Not possible.
