GLS Class (X167) Produced 2020 to present
23 inch wheels on GLS580 or GLS450 - spare tire?
Old Feb 9, 2020 | 12:35 PM
BlueGLS's Avatar
GLS500
I went to the dealer today to check out the GLS450 2020. It had those 23 inch wheels. However, the donut spare tire was not placed under the 3rd row seat coz this GLS had the Burmester option and its subwoofer component occupies part of the storage under the 3rd row seats. So the spare tire was placed right behind the 3rd row seats. Obviously the cargo area is eclipsed because of this spare tire.
How did you guys work this out?
Old Feb 9, 2020 | 02:24 PM
p5657587's Avatar
2020 GLS580
I got a GLS 580 with the 22" wheels and the high end audio. Car didn't come with a spare.
Old Feb 9, 2020 | 02:49 PM
sam9187's Avatar
2014 S550 - SOLD, 2014 GL550 - SOLD, 2014 GL63 AMG, 2015 S63 AMG Sedan, 2015 S63 AMG Coupe
That's odd because there is no spare tire with the Burmester option I have never heard of a spare tire placed in the trunk.
Old Feb 9, 2020 | 03:22 PM
GregW / Oregon's Avatar
2020 GLE 450; 2023 BMW M2 Coupe
3D High-End Surround Audio
I went to the dealer today to check out the GLS450 2020. It had those 23 inch wheels. However, the donut spare tire was not placed under the 3rd row seat coz this GLS had the Burmester option and its subwoofer component occupies part of the storage under the 3rd row seats. So the spare tire was placed right behind the 3rd row seats. Obviously the cargo area is eclipsed because of this spare tire. How did you guys work this out?
Good reason not to get that option. A couple of GLE owners with it on the other forum didn't think it was worth the money, either. In addition to the spare tire, you also lose the Interior Assistant.
Old Feb 9, 2020 | 03:30 PM
BlueGLS's Avatar
GLS500
Are those run flat?
Old Feb 9, 2020 | 03:31 PM
BlueGLS's Avatar
GLS500
Apparently the dealer got it as an option.
Are those run flat?
High End Audio equipped cars are supposed to come with TireFit instead of runflats.
Old Feb 9, 2020 | 03:32 PM
BlueGLS's Avatar
GLS500
I will check
Old Feb 9, 2020 | 03:38 PM
BlueGLS's Avatar
GLS500
TireFit not included. I am trying to add it as an extra. Although I had an unpleasant experience using it years ago.
I am still contemplating if I should swap the tires for runflats.
Old Feb 9, 2020 | 03:42 PM
No spare with High End Audio
TireFit not included. I am trying to add it as an extra. Although I had an unpleasant experience using it years ago. I am still contemplating if I should swap the tires for runflats.
It's interesting the DOG says "Requires TireFit," not "Includes." Pretty cheap. No, I would not want to use it either. Carry a plug kit and compressor.
Old Feb 9, 2020 | 04:56 PM
p5657587's Avatar
2020 GLS580
Yeah I got the tirefit thing. I didn't order it, but it came with the car.
Old Feb 10, 2020 | 12:08 PM
Daromo's Avatar
2020 GLS 450, 2024 GLS 580
The Burmester High End audio system takes up real estate under the floor load cargo protector. Can't get a spare or even a donut regardless of the wheel size I believe. I've got 21" wheels and all I got was a TireFit kit. I carry a compressor and a patch repair kit with me all the time and always have. Gladly, never had a flat. But my last SUV (Infiniti) had the optional super sound system with amps and subwoofer in the cargo area, but I still got a spare attached underneath the car. I don't hear good things about run flats. I've seen a post here where someone got a GLE or GLS instead of an X7 because they don't like run flats and couldn't get regular tires on their BMW out of the gate.
Old Feb 10, 2020 | 12:31 PM
Agree on run flats (Extended Mobility tires). I would still get the space saver spare to carry on trips when you are not using the 3rd row and have room.
Old Feb 10, 2020 | 10:22 PM
ksalno's Avatar
2011 Audi A4, 2014 E63S Wagon, 2020 GLS 580
I had run flats on my GL350 for 10 years and never had a problem. Never got more than 25K miles out of them though and they were expensive to replace. I never had any total failures with them but did seem to have a fair number of leaking valves that would require constant TP monitoring and refilling regularly.
Old Feb 10, 2020 | 11:19 PM
Daromo's Avatar
Sounds like the V-rated tires I had on my Lexus. Also never got more than 25K out of them, and were also expensive to replace. At least you had the knowledge that you weren't going to get stuck on the side of the road if you did have a flat and couldn't change the tire yourself.
