GLS Class (X167) Produced 2020 to present
Voice output doesn't stay at the adjusted volume
Old Jul 19, 2023 | 07:38 AM
glj12's Avatar
C300 Sport
Hi All, I'm using navigation on my 2023 GLS450 and I am trying to dynamically change the volume of the voice output. For example, with navigation, when it speaks I turn down the volume knob and it decreases. The next time it gives directions, it is back to the previous volume level, mid-flight. Has anyone else experienced this issue before?
Old Jul 19, 2023 | 08:33 AM
nc211's Avatar
2020 GLS450 (wife) / 2024 Ford Bronco (mine) / 2014 VW Tiquan (son)
I can’t recall on mine, but I do tend to say “hey mercedes, turn off navigation voice” and she turns it off. Maybe ask her to turn down navigation voice level?
Old Jul 19, 2023 | 06:39 PM
glj12's Avatar
C300 Sport
Do you think that by virtue of having Mercedes turn it down instead of me turning the knob will have a different result?
Old Jul 19, 2023 | 07:03 PM
nc211's Avatar
Not sure but worth a shot. I suspect there is a more permanent setting somewhere in the setting for the voice volume. Just have to fiddle with it…
Old Jul 19, 2023 | 08:13 PM
glj12's Avatar
C300 Sport
It's more this scenario: driving back home, kid falls asleep, and I need to (on the fly) lower the navigation volume. I'll test your theory out, but it's still not ideal given my use case.
Old Jul 20, 2023 | 11:10 PM
nc211's Avatar
What I tend to do as default setting is have the voice guidance turned off, nav screen in the center background on the dash along with the main screen, and just pay attention / glance at it here and there. It shows you on the top of the infotainment screen how many miles to go before your next turn, and what exit number to take if on the freeway, along with what lane to be in. I just take a mental note and keep my eye on how much further to go…
Old Jul 20, 2023 | 11:40 PM
wildta's Avatar
GLE 580
Does this occur only with the OEM navigation or Carplay/ Android Auto? If it's with OEM navigation, then maybe consider switching to CP/AA because I know both of them allow dynamic volume changes during navigation prompts.
Old Jul 21, 2023 | 05:46 PM
TNS550's Avatar
2015 MB S550 & 2020 MB GLS 450
Just as another point of reference, I do not have the issue. A few weeks ago I changed my profile to the one established with the Mercedes me Connect app and noticed the navigation volume was low. I went to the manual and, as it said, turned the volume up via volume knob while the nice lady was speaking. Volume has stayed the same ever since.
Old Jul 21, 2023 | 07:45 PM
glj12's Avatar
C300 Sport
I have this issue in Android Auto, but I see no settings that could indicate it overriding Mercedes' volume. Dynamic volume is off in my vehicle.
Old Jul 22, 2023 | 11:57 PM
wildta's Avatar
GLE 580
That's odd then. Maybe try removing your phone from the vehicle and your car from your phone and then pair them again just to see if that might "reset" things. You could also try soft resetting MBUX:
​​​​​Google maps also has the mute/unmute/alerts for voice navigation right on the main map screen. Waze has the same. It's not the same as turning the volume down though.
Old Jul 25, 2023 | 04:24 PM
glj12's Avatar
C300 Sport
Is this with Android Auto or Mercedes Navigation?
Old Jul 25, 2023 | 05:34 PM
TNS550's Avatar
Mercedes navigation.
Old Apr 20, 2025 | 05:50 PM
glj12's Avatar
C300 Sport
Bumping this year's later with the same issue, ha. Anything new here?
Old Apr 21, 2025 | 12:25 PM
mikapen's Avatar
I didn't add my experience to the original thread, so here's my comment.
There seems to be more than one voice reply sources.
Guidance instructions, reply to your request such as "turn on massage," and more.
For instance, adjusting NAV guidance volume doesn't affect "OK I'm turning on the passenger massage" or "I can't help you with that right now."
Also. You have to adjust the volume exactly while she's speaking or it won't take.
Old Apr 22, 2025 | 02:42 PM
glj12's Avatar
C300 Sport
To confirm, if turning it down exactly while she speaks and it still doesn't take, isn't that a different issue? Given that's the problem I'm having, any thoughts there?
Old Apr 22, 2025 | 04:19 PM
mikapen's Avatar
It sounds like you've eliminated my simplistic solution.
I was hoping it would work for you.
Old Apr 23, 2025 | 11:47 AM
glj12's Avatar
C300 Sport
Me too, I'm unsure how to move forward.
Old Apr 23, 2025 | 04:38 PM
W205C43PFL's Avatar
This is a tricky one, I don't think it is wise to simply reset factory settings of the infotainment system especially since it doesn't guarantee it will fix it but that might be something to try.
Old Apr 24, 2025 | 08:17 AM
glj12's Avatar
C300 Sport
I actually had the firmware for MBUX updated recently too, and that also did not fix the issue. This feels like a bug specific between Android Auto with Google Maps Navigation and MBUX.
Old Apr 24, 2025 | 08:36 AM
W205C43PFL's Avatar
I see. What is the android auto version running?
Old Apr 24, 2025 | 09:56 AM
glj12's Avatar
C300 Sport
The latest that is available on the Play Store to me: 14.0.651234-release
Old Apr 24, 2025 | 03:23 PM
W205C43PFL's Avatar
I wonder if there is a Canary release available that is worth trying?
Old Apr 25, 2025 | 10:47 AM
glj12's Avatar
C300 Sport
Nah, it's been going on for 2 years now, so most likely not.
Old Apr 25, 2025 | 11:05 AM
W205C43PFL's Avatar
Ugh that stinks.
