New user, lots of questions, kinda lazy, please be nice.
1) Is it possible to make the HUD smaller on this car? I'm coming from a CLS 450 with a nice, proportionate HUD and this one is enormous and more distracting than helpful if I can't make it smaller. I got it up and down. I got it brighter but I can't see anything that will make it smaller
2) Is there any way anyone knows of to manually lower or raise the third row seat? The motor on mine is burned out and it keeps triggering an error. I'd like to force it all one way or the other until I can get it in.
3) Does anyone know what controls the heated arm rests? Are they tied to the heated seats of the climate system or just totally on their own circuit. Damn near burnt my arm off earlier. Nice feature though
4) Does anyone know what "automatic lock" does in the settings? Not acoustic lock, automatic lock.
5) I watched a video on how to add a second car to the ME app but I think it was outdated and trying to repeat the same steps did not work. Any advice on how to get this new car in here without deleting my CLS?
6) I saved the dumbest for last. What are the buttons in the cup holder for? I didn't get the h/c ones just the stock one
Sounds like you've already found the only two adjustments I'm aware of: Brightness and Vertical Height Adjustment. I do not believe there is a way to "make it smaller."
There may be something a service tech can do manually, but I don't believe there's any manual adjustment of the 3rd row for us "end users." Only the buttons to power fully up or fully down.
The heated armrests are linked to the front heated seats. The center heated armrest will come on if either front seat heater is activated. The front door armrests are linked to individual front seat heaters.
If you engage "Automatic Lock," then the vehicle will lock once you hit a certain vehicle speed (I think it's approx 8mph).
Yes, it's definitely possible to have two Mercedes in the ME app. When I did it, I scanned a QR code somewhere in MBUX, in order for the app to accept it.
6) I saved the dumbest for last. What are the buttons in the cup holder for? I didn't get the h/c ones just the stock one.
The manual only references the heated/cooled function. If you don't have that function, then someone else will have to chime in. My guess, from previous Mercedes models, is that the button may release a part of the cup holder, in order for you to remove it for easy cleaning. Or, the button may allow you to alter the size of the cup holder, to accommodate different sized drinks.
Hope that helps!
"Someone made the screen smaller and I couldn't make out how fast I was going, officer!"
Maybe one of these little system hacker guys will eventually find a way to sell a mod to make it smaller.
I was somewhat disappointed that our new to us GLS 580 doesn't have the HUD but maybe that's a good thing based on the thread.
. I don't think you are missing much, I'm a little disappointed to be honest and probably will end up disabling it unless I can figure out a solution. It's literally bigger than the display on the dashboard, it's ridiculously too large.
I adjusted it vertically to move it out of the way a bit more than factory setting, but to suggest that it obscures the field of vision sounds a bit extreme. There are times when I catch myself looking at the physical cluster because I forget the HUD is there. There are different settings, including a minimalist one that only shows the speed and not much else. I, for one, like having the map there, too.
https://m.youtube.com/watch?v=F5h10sE4ams
I don't need it now but always good to know.
The interface leaves a lot to be desired though and the fact you only have the stupid little thumb trackpad to make these adjustments just compounds the frustration of having to do all this yourself.
I do also recommend a full reset and starting over if things get out of wack. Since there are no values on most of the choices all you have is the clicking and your memory to know where you are from start.
If you spend the time with it though you should get favorable results like I did.
