Drive axles pinging/clicking noise
This happens when accelerating from a full stop.
In the beginning, I noticed it when I stop and reverse up on my drive way to get the GLS inside the garage. Then a single ping/click will be heard.
Then, I started noticing the same behavior on stop signs, when GLS stops completely, and then u start accelerating you can hear the same single ping/click.
It is not caused by gear shifts and you can hear it best when windows are opened. The sound is very metallic and its like there is an echo in it.
Hope I managed to explain it to make sense.
Thanks in advance
If they can't replicate with a test drive, they can take the next step - Chassis Ears.
I was not aware regarding "chassis ears" option but I guess I need to change the dealership and get this checked again.
whenever we’ve had the ticking noise, it’s been something in a tire. Either a pebble or a nail, screw, even had a bolt in one before. BUT that is not to say your wheel bearing isn’t going bad either. That happens on all cars. I’m about to replace one on an 11 year old VW with 49k miles. And I had two go bad on my former W212 inside of 70k miles. However, I have never heard of “yeah, they just do that” before.
We spent a ton of time going back and forth, back and forth...with the "ears"...it is a bearing (or bearing holder). I need to stop at the shop and have him remind me what one it is.
Thanks in advance
Can you please share how did they diagnose this issue and do u use the factory or CPO warranty to get it covered? Thanks.
not sure if cpo will cover it because in Canada the cpo only covers engine and transmission.
bearings don’t click, they grind and hum when going bad. Debris in tires click, and sometime bad u joints on drive shafts. Also loose brake pads can click/rattle around in their seats if they come loose or replaced with non oem pads with new springs. Bearings don’t just “do that” sometimes.
so they did end up checking the pads and re greasing the slide points and then packed my bearings with more grease and told me the noise is gone…. Well for now it is gone. Hopefully it stays that way but I’ve kept my repair order open at the moment so I can go back if it decides to show back up in a couple days.
I thought the bearings were closed, meaning you can’t open them to service them. You just replace them. In fact, I don’t think I’ve seen a wheel bearing being able to be “repacked” in the last 20 years or so. But, I’m no mechanic myself.
Absolutely keep that ticket open.
I get they are all busy but it seems to me nobody wants to spend time diagnosing a weird issue.
It's probably not the case for you, but it's possible.
